Steve W Posted December 13, 2017 Author Posted December 13, 2017 Philip.....the mast are tabernacled....totally fixed from rotation. Presto 30....my dream boat. Quote
Paul356 Posted December 15, 2017 Posted December 15, 2017 Um, does the Coast Guard really check for rotating masts? Quote
PAR Posted December 15, 2017 Posted December 15, 2017 At night if the mast is rotated, more than would look normal, I'd bet the harbor patrol would drive up and ask about it, if someone was in a bad mood. If they do stop, you know they'll find something to give you a ticket for . . . Quote
Designer Posted December 15, 2017 Posted December 15, 2017 Coast Guard or not, you really want to set up your nav lights as accurate as you can. You want to let other craft know what type of vessel you are and what your heading is so that they and you can take appropriate action. The tabernacle does prevent mast rotation but remember that we wedge the tabernacle 2 degrees so that the main mast comes down clear of the mizzen mast, I like to account for that. Quote
Steve W Posted December 15, 2017 Author Posted December 15, 2017 Thanks everybody. Graham, do you put the sail track offset as well? And Chick, that light you have is significantly less expensive...any regrets? . Quote
Chick Ludwig Posted December 15, 2017 Posted December 15, 2017 Steve, it works fine, appears well made, and was easy to mount. I thought I was ordering the version for two wires where you switch polarity to change from nav. to anchor lights. After fussing with the supplier because the posting wasn't clear about how to order the right one, I finally gave up and just ran an extra wire. No big deal. I like the light and just added a switch to change from one mode to the other. I looked on Amazon and Ebay yesterday to try to find it fr you, but it doesn't appear to be there anymore. I don't remember the company name now. I'll dig through my files and see if I can find the receipt. If I do, I'll let you know. Quote
Designer Posted December 15, 2017 Posted December 15, 2017 I really liked Jays light but it was priced above my comfort zone. I trolled the cruising forums for owner satisfaction and found that there was a high failure rate with expensive return freight and time delays. I am glad that Jay has had good service from his light, hopefully they have corrected the problem. Beside the two wire feature It was small and light. I had not heard of Chick's light when I bought mine. I chose Aqua-Signal because they have a good reputation and warranty and the light is very strong and our local wholesaler delivers them free. The downside is that they are very tall, even taller with the anchor light. They have a clever removal system which I removed and modified to reduce the height. By modifying my light I probably voided my warranty but I was impressed with how well it was potted in epoxy. I did test that the light did indeed work before I messed with it. It has been very good so far but having an anchor light built in would be nice. Yes I do account for the tabernacle offset when installing the track. Quote
Steve W Posted December 15, 2017 Author Posted December 15, 2017 OK, great info. I ordered all the electrical stuff. I'm getting ready to paint the cabin interior. The only thing stopping me is radius-ing the sharp angles (bunk edges, etc.) . I think a 3/16 router bit seems about right, but 1/4 would be softer but weaker. Any thoughts? Quote
Docpal Posted December 16, 2017 Posted December 16, 2017 Just learned an interesting trick down here for an anchor light that I hope to try out in the next few weeks when I (finally) launch Petunia and get her out to her new mooring ( a loooong story there, which WILL follow in time...). People down here who don't want to hassle with the wiring, switches,etc. to connect an anchor light simply go to the local big box store(actually there IS no "local" big box store near Loreto so they have friends bring them down in their baggage..OR drive the 200 plus miles down to LaPaz.)and buy one of those "solar walk way lights" that look light landing strips for alien craft in driveways everywhere. It already HAS a solar cell built in to charge it during the day, and it automatically turns itself on at night. NO battery drain, NO wires to screw around with, etc...Figure out a way to clamp, or suspend it from the topping lift,etc. so you have a 360 degree field of view. Might be a quick solution for occasional usage... Quote
PAR Posted December 16, 2017 Posted December 16, 2017 Most of those solar walkway lights will not project a light the required distance (2 miles) to qualify for an anchor light. 1 Quote
Ken_Potts Posted December 16, 2017 Posted December 16, 2017 And if you leave the boat in a marina you'll have people telling you all night long that you left your anchor light on Quote
Docpal Posted December 16, 2017 Posted December 16, 2017 Down here ANY light is considered better than none, and with little background harbor lighting, "city" lights etc. you can see things from greater distances. I'd bet there's less of a chance of getting a fine, than there is of the CG/ local authorities pacing off 2 miles to check your light... 1 Quote
Steve W Posted December 16, 2017 Author Posted December 16, 2017 We don't deal with tides around the freshwater lakes so I just anchor in such shallow water that I rarely run up an anchor lights. They just attract bugs. But Jazz Hands and I are planning some big trips so I guess I better do it right. Thanks for all the suggestions and help. Quote
Designer Posted December 16, 2017 Posted December 16, 2017 Bill, I like the idea and I am going to look into it. While I am fussy about my nav lights I am more interested in being seen by a power boat running faster than common sense should dictate, not to mention an aggressive marine patrol cop. I do not care about meeting the 2 mile rule but would prefer to light up some of the boat with the light rather than looking like a star at the top of the mast. I had a coastal freighter captain once tell me that he only saw me anchored in an open roadstead at the last minute as he thought that my masthead light was a star. I once had a client who was asleep in his 38 foot Garden ketch in a designated anchorage with his mast head light on. He was thrown out of his bunk when a Sea Ox ran into him at full speed. The Sea Ox climbed up and over the rather high freeboard and tore up the mizzen mast and drove the entire cabin forward a couple of inches. The client was okay after getting stitches for the gash over his right eye. The ketch was totaled due to neglect and incompetence over a long protracted law suit. Like Steve I mostly anchor in out of the way places but that is not always possible. My recent cruise in the Pacific Northwest was an example. With their high tides and signs in some places showing EEL GRASS, NO ANCHORING. The shoreline is often boulders or cliffs. Quote
Hirilonde Posted December 16, 2017 Posted December 16, 2017 3 hours ago, Designer said: I do not care about meeting the 2 mile rule but would prefer to light up some of the boat with the light rather than looking like a star at the top of the mast. This is exactly why I liked the cockpit light in a busy harbor and used my miner's lantern as well as the "star" on the top of my mast. I can't read much by it, but it gives the cockpit a soft glow for ambience and safety. Quote
Steve W Posted December 16, 2017 Author Posted December 16, 2017 Graham, what is a Sea Ox? (I doubt it was in Lake Erie!) Is that like a Sea Lion or a Walrus? Quote
Designer Posted December 16, 2017 Posted December 16, 2017 Steve A Sea Ox is a locally built center console runabout. They are sturdily built and are favored by fisherman. Quote
Jknight611 Posted December 17, 2017 Posted December 17, 2017 We have a friend that swears he had his anchor light on, and he was in a charted anchorage hit by a large pushboat pushing 4 barges in the middle of the night. They survived but his Chris Craft Apache didn’t. He was somewhat backlit and his anchor light blended into the background light field. On our CS20.3 we have a anchor light and a tiny blue LED light in the cockpit. The little light gives the boat some “definition “ from background clutter. Both because it is blue and lights up the cockpit a little. Odd color makes it notable too! We have “sneaky” barges here! Painted black, barely lit and the pushboat is 600 feet back you just hear a shushing sound from the barge bow wake and they are on you! Quote
Steve W Posted December 17, 2017 Author Posted December 17, 2017 A bit of progress to show. First, I decide the bunk was just a bit narrow for me. I sleep on my back with my arms at my side, so I decided to add a little filler. Here is the "bunk" side. And here is the "hard tack and water" serving side. More likely fine Scotch and cheese. Here is the simple support. It can be stood on or knelt on should you need to go out the hatch with it still in place. Here is the start of my mizzen tabernacle. I can't glue it in until she comes out of the basement. And while I'm showing progress, here is my tiller handle before varnish! Tonight I am going to work on the electrical stuff! Quote
Jknight611 Posted December 18, 2017 Posted December 18, 2017 Looks great! You will love the tabernacle! We can rig in 8 minutes tops and be underway with our tabernacle. 1 Quote
