Ocracoke 256 hull #2 Build
smccormick
 Share
20 hours ago, Kennneee said:
Beautiful work Steve!
1 hour ago, lenm said:
Looking good Steve!
Are those pre-drilled holes in the engine bracket photo?
Thanks Guys
The dark spots are 1.25" (30mm) fiberglass dowels installed in the transom as both moisture barrier and crush collar for the engine mounting bolts.
  • 1 month later...
  • 1 month later...
I used the Awl Grip product called Awl Wood. This image has just three coats. One prime, I used the clear primer, and two finish. That sealed it until the rest of the painting was completed. Then 7 more coats. You can do 2 coats a day with light sanding in between. The say 8 years on a vertical surface. I hope so. It is hard as nails after it fully cures.
On 10/25/2018 at 9:40 AM, hightechmarine said:
Awl Wood
 Thanks for the recommendation of awlwood.  I was going to do a clear LPU, but I think I may go with awlwood after reading up on it.
Everyone,
Thanks for the kind words on the transom.  I have spent many years on sportboats with all the teak trimmings and would like to do the cockpit too, but I'm just to cheap and lazy, and don't want the extra weight so this and the helm pod are the only teak going on it.  The toe rail will be sepele so if I get tired of maintenance I won't feel to bad about painting it.
The more perpendicular to the sun, the more abuse it takes.  Small radius rounds and corners go first.
I'll be curious to hear from people who use such stuff a few years down the road.  The repair process is what I am skeptical about. It has a nice "wow factor" to start with.
I'm right there with you.  I've always had boats with some amount of bright work and understand the commitment to keep it well maintained.   If I can extend service intervals I'll consider it a win.  Seems like it's always an experiment.
  • 2 months later...
All righty, I guess there was a database restore done.  We'll try this again.
Awlwood, one application of yellow primer and two fill coats of clear.
Sapele mahogony toe rails 1.125" tall, width tapering from the front at 4.125" to 2.875" at the shear downturn.  Rail continues to break at 2.875".  Top is slightly convex blending into the two edge radii.
 Share
