S10n #993 Progress and Question
mjshp
 Share
Progess!
So the breasthook is in, gunwales are on and the quarter knees are secure. I have tacked togeter the panels between the wires! On to the next step of filet and tape.
So last night I was laying everything out to fillet and tape the aft starboard chine, and doing some basic prep of the tack "welds"--pulling the wires and knocking down a few big bumps left over--to make the next step easier, and it occured to me, things would go much better if I could pull all the wires, prep all the seams and fillet, then tape the boat in one fell swoop.
The question is, given that I have a small fillet of epoxy between every wire, can I take out all the wires and prep all the seams, or should I leave the wires in as I work on one seam at a time? I have visions of the boat poping apart as I remove the wires--oh the crazy visions that come from having never done this before.
As always, thanks for the help and advice.
I'd do 1 side at a time. The process can be time consuming. Pull all the wires on that side, watching the most highly stressed spots to make sure they don't let go. Clean up any remaining bumps. Cut your glass tape to length before you mix your epoxy. (Actually, you can cut the tape for both sides at the same time. Just make sure it doesn't get near the epoxy until you're ready to lay it in.) Then recoat where you'll be filleting w/ unthickened epoxy. Mix thickened epoxy and apply the fillet down the first side. Go back and clean up any excess. Now GENTLY apply another coat of UNTHICKENED epoxy over the fillet, smoothing as you go. Then lay the pre-cut tape along the filleted seam, spacing it evenly up the sides & on the bottom panel. Again, use your brush to GENTLY set the tape into the wet epoxy. The epoxy will soak into the tape, changing it from white to grey to clear. As it soaks in, you'll see the areas that need extra attention. Try hard not to disturb the fillet. If it wants to stay dry, add a little extra epoxy, but not to much. If its too wet, the tape will lift off the fillet. Not good. Watch for epoxy runs. Clean them up before the epoxy sets.
Once you're satisfied w/ one side, do the other.
I made longer mini epoxy fillets to hold it together when the wires were removed. I remember thinking how firmly they held when the wires were out. I filled a zip lock plastic bag with thickened epoxy and cut a small hole in the corner to extrude epoxy into the join. I then made a mini fillet with a cut down tongue depressor with a small radius. To avoid any problems with sanding /secondary bonds I did this one night and the next morning removed the wires and filleted/taped over everything while the mini fillets and epoxied ply were still a little green.
With respect to taping over fillets I prefer to pre wet the tapes on a bench...it seems easier that wetting out the tape on the epoxy fillet.
Cheers
Peter HK
I made no tacks at all. I just left the wires in and did the filets and taping as one process using primary bonds of everything and no sanding until it was all done. I removed the wires with heat just before rounding over the outside corners. Removing the wires is not that hard to do and this saved a lot of work dealing with cured epoxy and prepping for secondary bonds.
 Share
  • Similar Content
    • By ForthBridge
      Hello everyone,
      I last posted on here a few years ago.  It's taken me sometime to convince my wife to give up the living room to an N11.
      My Spindrift N11 project is called South Queensferry Electron - in recognition of Donald Crowhurst's Teignmouth Electron - https://en.wikipedia.org/wiki/Donald_Crowhurst
      Following the usual 'messing-about' convention, here is my progress right up to when I found the courage to saw her in half - earlier today!
      Nidaplast is very flexible and I epoxied and peel plied each piece of the hull before assembly.  Bulkheads are carbon fibre and Nidaplast, three layups of biaxial cloth.  A diamond cutting wheel on a Dremmel made short work of trimming excess from the bulkheads and transom.
      The hull still needs finishing, as do the bulwarks.  Knees still to fit as well, that's the next job.
      So I realise that 6mm ply would have been the best route to go down.  However, prior to this build I had not worked with West Systems or carbon fibre before.  The SQE is a 'learning by doing' project in preparation for the retirement boat.
      I will update with more photos as work progresses.  I live in Scotland, the weather is getting colder and less conducive to epoxy use and, of course, I have to give the living room up for Christmas.  Progress might be slow!  However, with the hull complete I can cut out the rest of the Nidaplast components and get the sailing rig ready.
      Happy boat building to you all!
      Jim
    • By William
      For want of a decent local plywood supplier I will be building in 5mm nidacore honeycomb sandwich, carbon outside, vectran and glass inside. If I can get my hands on some affordable basalt fabric I am sure I will find a few panels for it to feature. It is certainly not going to be as enjoyable as building in wood but at least I will get to learn a few new skills along the way. A lighter boat is almost a guarantee, but that all depends on how many laminates will give me the impact toughness I require.
      I do have a partial sheet of nice 6mm ply and will cut the transom, mast partners and a few other small parts from that.
      The nidacore sheets are 7ft x 4ft, which, as fortune would have it, is just long enough to cut the main hull panels from 3 sheets, one being halved and butt-joined to the full sheets just like the plans for plywood.
    • By Luke
      Hi everyone, this is my first post--I've been lurking here getting lots of good info as I build and finally have a few questions myself!
      By now the boat is 3D and wired together. The hull, bulkheads, and transom all seem to fit well, and the boat has no twist in it that I can discern. Measurements from the peak of the bow to the corners of the transom are 109" +/- an 1/8", and sighting down the centerline, the tips of the nesting bulkheads "disappear" below the transom at the same time.
      I've made a number of spanish windlasses to pull the sides together between the forward and mid bulkhead, to pull out the 1/2" gap between the bottom and the bottom of the nesting bulkheads, to pull the forward bulkhead forward onto its lines, and lastly to try to flatten the bottom seam between bulkheads slightly to close a gap in the bottom panels.
      The question is how much of a gap along the keel seam is acceptable? It goes from no gap at the transom and widens to about 1mm around the nesting bulkheads, and up to a maximum of about 3mm halfway between the forward and mid bulkheads. I think the epoxy fillets will cover it just fine, but I just want to make sure it's not a symptom of a larger problem.
      Also, the plans don't really give dimensions to make a breasthook or quarter knees--do I just make these to fit the shape of the hull as it stands now? The instructions say the breasthook (included with the kit I suppose) is important to ensure the bow takes the correct shape--so what gives? The sheer lines look nice.
      Lastly, I centered the kerf gap of the nesting bulkhead on the "center frame" lines running down the sides--is that correct?
      Thanks!
      Additional photos
      Looking aft:
      chine
      bow and gap
      forward bulkhead
    • By PlaneCrazy
      As my first post on this forum I may as well start a build thread.
      I should start out by saying I have little to no experience with boats, but I love building things and my wife says we don’t need any more bookshelves or lawn furniture.
      I have read many of the build threads on this site and have appreciated being able to get a more in-depth understanding of the process.
      I also watched Alan's set of videos.
      So one day I called and talked to Alan, and ordered the kit.
      The next thing you know I have a large stack of wood parts, several bottles of epoxy, and rolls of fiberglass tape.
      Onward,
      Mike
    • By mjshp
      Went to check twist and square, there is shy 1/16th difference in the centerline to outer edge of the hull, and the similar shy 1/16th from transom corner to bow.
      Is this shy 1/16th small enough to call it good or should try to work it out?
      What other dimenions should i measure to check the squareness and for twist?
      Thanks,
      Michael
