I’m about to start a new build (over on the other Main Forum), and I’m thinking about how I’m going to cut out the panels out of Okoume.  How do you cut your parts out?  Do you use a jig sawIMG_0473.thumb.jpeg.47c3a5a3601c5dd65c55f4c8a8ddeea9.jpeg a small circular sawIMG_0474.thumb.png.67926b5670d54944abf60b59dc05fc3c.png or something else?IMG_0475.thumb.jpeg.45a3259d930f5d07bb87e5aa6585ccdd.jpeg
I’ve used two of these tools for doing this in the past.  Since then, my mini circular saw died, and my jig saw is ready to retire.   Before I buy one of these, I’d like to see what all of you non-kit builders use for this task.
I used a jig saw and on parts with long curves and/or straigh lines I used a circular saw. If you are finishing bright, then fit is really critical and I would cut a tad large and use a block plane to tweak the fit. When using a jig saw use good blades and sharp, even new.  I would rather waste a blade then get tear out.
I’m leaning to using the jig saw.  As I recall, the mini-circular saw was nice to use, though.  I block plane all my lines, as I don’t trust my jig saw technique.  Maybe one of these nice, new ones will perform better.
G’day
I use a jig saw with a laminate blade.
It cuts Okoume really cleanly so I cut to the line, no finishing required.
Also most panels are duplicated port & starboard so stack the plywood sheets & cut two panels at once.
I marked out & cut all the hull panels & bulkheads for my CS17 in one day.
cheers
John
  • Thanks 1
In the past, I have used my crappy Craftsman jig saw, cut shy of the line, and used a block plane to get to the line.  I also do port and starboard sides simultaneously.
I’ve built nine boats, and counting.  Occasionally, though, I like to stand back, and think outside the box.  “Might there be a better way?”  Something caught my eye at Lowes yesterday, which turned on a light bulb in my pea-brain.  So, I drove over to Harbor Freight, and bought this.
This is what I mean about thinking outside the box.  It might really suck at cutting curves.  It might really suck in general.  But the multitool worked like a champ, when relocating Avocet’s centerboard 10” forward.  The experiment is going to cost me only $7.50.  If it fails, I’ll probably suck it up and buy a cordless jigsaw.  That’ll set me back about $200, but at least I won’t have to use that old saw anymore.
Well, that was fun— NOT!  It was worth a try, but it was not ideal.  I guess I’m going to bite the. Bullet and get one of these.  IMG_0496.thumb.png.f9b9ee8cd24a280096ff8d207102ec8a.png
I already have enough batteries, so I can save a buck or two there.  The Bosch, Rigid, and Milwaukee all looked good, too, but it would mean buying the battery, and having another battery charger laying around.  Now, I just need to get some of those new blades…
I used a Grizzly corded Jigsaw when I built the Suzy J. IT worked great, but the cordless revolution really was pushed forward by lithium-ion batteries. That DeWalt looks pretty nice.
For one thing, it has a brushless
motor, which runs smoother.  The new blades have fancier teeth, too.  No screwdriver to install them!  And the baseplate is super flat and smooth.
