Murray Posted August 13, 2023 Author Posted August 13, 2023 Time to stop procrastinating.... Carlin in. 1 Quote
gray duck Posted August 25, 2023 Posted August 25, 2023 Carlins look great! I'm confused with your previous post with what appears to be a drain going from the mast (or mast step maybe) through the hull. ??? Never seen this before. My $0.02: When people say a mast step needs to be drained, usually it just means into the bilge to prevent water sitting in the "wooden bowl" that the bottom of the mast is in. Quote
Hirilonde Posted August 25, 2023 Posted August 25, 2023 The plans call for the drain tube for the main mast step to go through the hull. I have mine coming aft through the forward bulkhead and thus draining into the bilge. Either way, it is important to not have standing water in a hiden place. Quote
Murray Posted September 10, 2023 Author Posted September 10, 2023 On 8/25/2023 at 11:54 PM, gray duck said: Carlins look great! I'm confused with your previous post with what appears to be a drain going from the mast (or mast step maybe) through the hull. ??? Never seen this before. My $0.02: When people say a mast step needs to be drained... As Dave ( @Hirilonde ) says, the plans call for it to go through the hull, after thinking on it, I thought why not? Quote
Murray Posted September 10, 2023 Author Posted September 10, 2023 Carlins sorted, a little shaping left to do on the transom top to blend all the differing angles in, next on the list was Gunwales. I had thought I'd scarf two bits of Jarrah together, and have a single piece I'd bend to the inhales. Jarrah is so short grained though, it wasn't long until I heard the unmistakable sound of a single piece of wood becoming two bits of wood again. So I resorted to laminating strips together. Makes a glue-up and positioning of 12 pieces (???) against the boat a lot more complicated, and the 3mm bite the tablesaw blade takes meant I was not sure I'd have enough wood to get it done. I did, but that was all that was left over. Oh - a man can clearly never have enough clamps... I've taken the gunwales off to sand clean, hope to complete that tomorrow, then the decks can go on.... Still a long list but we are getting there. Quote
Murray Posted November 8, 2023 Author Posted November 8, 2023 I've been meaning to show the stem since I fixed some time back. I cut a batten the width of the finished stem, drilled many small holes along the centreline, then wrapped it in plastic. Then I marked out the centre line of the stem of the boat, and the bits that would extend past the batten and sanded those back. Then after nailing with little pins, the batten bent to the shape of a straight stem. Backfilling with epoxy and fillings between the batten and the hull was relatively simple. Removing the batten and the stem looked like the photo below. A bit of cleaning up and now it looks like the second photo. haven't been able to work on the boat for some weeks but now the sails are here, and the trailer ready to collect, I better get back to it... 1 Quote
Murray Posted November 14, 2023 Author Posted November 14, 2023 Coamings cut roughly and steamed into place; 2 pieces of Jarrah cut into 3mm strips. I'll epoxy them together with filler from the sawdust; it's pretty fine so should work. But the next real step is the rub rails at the bottom of the top strake. I've cut the strips out but still not sure how to hold them in place while the epoxy goes off. Brad pins will stop them sliding up or down, but will not hold them close the plank. While I ponder that I'll carry on with getting the deck trimmings ready to glue on. So rubrails, then decks, coamings, and gunwales, followed by deck trim. Then the wood is basically all in place. Sanding and painting the interior, varnishing the timbers and - well - getting close! Quote
Kennneee Posted November 14, 2023 Posted November 14, 2023 You boat looks beautiful Murray! Keep up the fine work. Quote
PadrePoint Posted November 15, 2023 Posted November 15, 2023 This looks like great craftsmanship. 1 Quote
Hirilonde Posted November 15, 2023 Posted November 15, 2023 I made my own simple clamps for the plank laps and attaching the sheer plank trim. They are simple rectangular U shapes cut from scraps of 3/4 ply. The inside opening of the U was about an inch wide by 6 inches long. You fit it over the lap or trim and lap, then force angle shims to tighten the piece together. Quote
Murray Posted November 21, 2023 Author Posted November 21, 2023 On 11/14/2023 at 5:29 PM, Kennneee said: You boat looks beautiful Murray! Keep up the fine work. cheers Ken Quote
Murray Posted November 21, 2023 Author Posted November 21, 2023 Thanks for the kind comments guys, and Dave for the tip on clamps - sometimes you feel as though you are getting somewhere - then you get confused again. Ah well - always tomorrow... Quote
Murray Posted August 9, 2024 Author Posted August 9, 2024 And here we are, August '24, and I haven't done a single thing on the boat... sometimes you need a break just to smell the wind. I think mines about to come to an end... Quote
Murray Posted June 12 Author Posted June 12 ...another year has passed. And another year - with not a day spent in the shed. then one day I found myself back in the shed, with epoxy in my hands. I attached the rub strip on the lower edge of the top plank and liked the way that looked. I had found a guy who had a bit of Jarrah, so bought a bit, and ran it through the bandsaw making 'planks' 2mm thick. I laminated these over the top plank ply. why? - Cos I thought it looked pretty. I figured out that decks were next, but first I needed to get the coamings fitting perfectly, ready to glue into place, which meant back filling thickened epoxy around the hand cut support, then sticking plastic sheet over the coamings and clamping into place. that would allow me to remove the coaming and have a nice surface to flush trim the decks against. Then they could go on, and then the coamings. So I did that, but the plastic I wrapped around the coaming had a few wrinkles, so we did that bit again - this time with a bit more success. Now the decks are on, and the curved coamings at the front are on. I put a vertical piece of Jarrah behind where they join - should make it strong. The rest of the coamings are cut ready to go on, the gunwales are dry fitted, now ready go on, and I've looked at decoration for the bow. As I cut out the piece for the bow, the offset fell to the ground in such a way that I thought about putting it on the frontside the of the coamings. thoughts? Tomorrow I'll paint the decks in a gloss white, glue on the coamings, then the gunwales can go on, then - well it's suddenly getting there. Loads of internal grey paint and varnish to go one the brightwork notwithstanding. The masts are ready, booms are ready, sails are ready. Soon, it will be fittings time and the only thing to make will be the tiller. So hopefully, unless I change me mind, we could hope to get on the water by the start of summer - say Sept/Oct...? but which year? 1 Quote
PadrePoint Posted June 17 Posted June 17 Glad to see you back at it. You’ll really like the results of your work. Quote
Murray Posted July 2 Author Posted July 2 A boating mate was over looking at progress. "It's going to be a piece of furniture" was his comment. "So important to get the shadow lines between the rich dark timber and the white gloss deck spot on...'. Or it will be gloss when the next coat goes on. So a bit of head scratching, and a couple of hours sanding I hadn't counted on, and now at least the coamings fit agreeably against the inside of the decks. It really good to get someone who has done it before and knows some of the pitfalls. Of course, when the gunwale goes on it will be the same thing again on the outside of the decks, but now there are only 8 pieces of wood to glue to the boat.... then paint. and sanding. and more paint. 1 Quote
