Wile E. Coyote Posted November 7, 2016 Posted November 7, 2016 Hi all, I bought a small used trailer for my Spindrift 11, it's almost the smallest load trailer that Karavan makes, but the max load is still 1000 lbs. My boat hull only weighs about 100 lbs, plus a little more for some rigging and so on. So it's a bit of a bumpy ride. Has anyone tried taking out leaf springs, or is there some other way to adjust the trailer suspension for a lighter boat? Thanks, Matt 1 Quote
PAR Posted November 8, 2016 Posted November 8, 2016 Yep, you can remove spring leaves if there's more than one, which is pretty common on small boat trailers. Conversely, you could simply replace the "stacked" spring, with a lighter single leaf spring of a more appropriate weight. Quote
Peter HK Posted November 8, 2016 Posted November 8, 2016 You can try lower tyre pressures- on a lightly loaded trailer like this you don't need much pressure. It can soften the ride quite a bit. I use a standard box trailer to transport a small dinghy but also use it for heavier loads so I just adjust the pressures accordingly. Cheers Peter HK Quote
Wile E. Coyote Posted November 8, 2016 Author Posted November 8, 2016 Thanks. I'll see if I can take out a spring. Quote
meester Posted November 8, 2016 Posted November 8, 2016 Hi Wile, Â Thanks for asking your question. Â It's one that I have had on the back burner for a while. Â I looked up leaf springs on a couple of on-line sites, and they're not so expensive, especially for light springs. Â Bob Quote
Wile E. Coyote Posted November 9, 2016 Author Posted November 9, 2016 Well I looked at my trailer and the springs have three leaves. There is one long spring that is attached to the trailer at each end, under that there are two shorter springs that are fastened to the longer one by some kind of clip. It looks like I will be able to take out the two shorter springs and just leave the single long one. I don't have time right now, but I'll try that some time in the winter. Matt Quote
PAR Posted November 9, 2016 Posted November 9, 2016 On a stacked spring set, you only have one choice, the leaf with the eyes on it is the only one you can attach, so the shorter leaves have to come out. Typically they'll have a locating pin in the center and a sheet metal leaf alignment clip on the outer ends. Pull the U bolts, remove the spring and everything will be apparent. Running much lower tire pressures, will just eat up the thread (commonly cupping it), dramatically lowering its lifespan. Quote
Don Silsbe Posted November 14, 2016 Posted November 14, 2016 But I recommend waiting until spring to do that job. Â For some reason, it only seems right. Quote
Wile E. Coyote Posted November 15, 2016 Author Posted November 15, 2016 You made me check this new post, and it's a Dad joke! I'll get you for this Thrillsbe! Quote
Chick Ludwig Posted November 15, 2016 Posted November 15, 2016 Trust Thrillsbe to spring into action with something like that! You should bounce him off this thread. Quote
Wile E. Coyote Posted November 16, 2016 Author Posted November 16, 2016 Another groaner! But I will rebound. 1 Quote
Action Tiger Posted November 16, 2016 Posted November 16, 2016 Can I hitch my wagon onto this thread? Seems you're all having a ball. Sorry, I couldn't bite my tongue. Peace, Robert Quote
