Brodie and I have been plodding along.  The access holes have been cut in, reinforcement rings made, and cleat locations established.  The underside of the decks have received two of three coats of epoxy, and all backing plates are glued down.  Soon it will be time to tape and sheath them!
I’m creeping up on gluing down the ama tops/decks, but I’m proceeding cautiously.  Once certain areas are glued shut, there’s no turning back; there’s no access.  So, I’ve been making epoxy-bushed holes for all the things that’ll be screwed to those decks, tweaking, fussing, etc.  Tomorrow is probably deck day.
This morning, I topped off all the screw holes with 404-thickened epoxy.  IMG_1223.thumb.jpeg.122645fef768e90e016852530a23f50e.jpeg
This afternoon, Brodie (my grand-neighbor and assistant) and I moved the side panels for the vaka (main hull) into the garage.  IMG_1224.thumb.jpeg.3de21fa990dce83803f0d590a13a8b4d.jpeg
We then cut out the vaka’s bulkheads and  bulkhead stringers.  After he went home, I glued them all up.IMG_1222.thumb.jpeg.9e8d272fb186d90664d4e6cfc3d39264.jpeg
Long day today.  It started with my sanding the edges of this tape, to get a smooth transition.  IMG_1271.thumb.jpeg.5caceb52c91d21d0fae9e6530f456b07.jpegIMG_1269.thumb.jpeg.703456cbe3a6bcbef7c58cb71d4181db.jpegNext time, I’ll use Peel Ply.  This afternoon, I sheathed the outboard sides.  IMG_1273.thumb.jpeg.a087daf477426c91b558aae42ac548bd.jpegThe transition is smooth, so I’m happy I spent the morning sanding.  Sort of.IMG_1274.thumb.jpeg.f8e626eeb3e616b266e69ea48f1fc8df.jpegIMG_1275.thumb.jpeg.cd3feba1f767a331ec390df7321274e3.jpeg
I’m doing a fill coat per Russell Brown’s method.  I used WEST 410 filler mixed 1:2 with epoxy, by volume.  (I was instructed to pack the measuring cup, and not loosely fill it.) I rolled it on with a mohair roller, and went over it with a fine foam roller.  The results are outstanding!
The amas are finally done.  They are ready for final sanding (outdoors, later) prior to primer.  My neighbor-helper has been a great help.
This makes room inside the shop to go 3D with the vaka.  That should happen in a few days.
All the hulls on this boat have two stems—  an inner and an outer.  The inner is used for assembly purposes, to properly define the hull shape.  The outer stem is a sort of cap, that allows for some shaping.  They have two tapers.  Today, I accepted the challenge for the vaka.  I was very proud of my work.  During the high-fiving process a moment of clarity occurred.  I had forgotten to allow for the thickness of the hull’s sides!  So, I get to do it all over again, but making it 1/2” wider. IMG_1347.thumb.jpeg.74fea9c196e549b516aa6ddb04672f70.jpegIMG_1349.thumb.jpeg.9ac53d0a3daf3612f0ede6a6ac10d4ee.jpeg
Also, for this build, I’m using a few of Russell Brown’s techniques.  One of them is to use flat-bottomed paper cups for mixing epoxy.  My bride is very cooperative in helping me obtain these.  (Her’s is the smaller of the two.)
I’m clipping right along on the trimaran.  The bottom is on, and I‘m working on the c/b trunk, to drop it in place.  I’m setting it up to take the slick B&B Starboard pivot cap with o-ring.IMG_1471.thumb.jpeg.15bb47ef8391b1c0f11b4139cd901240.jpegIMG_1469.thumb.jpeg.72a71921b8a33dcb4989f9bfc41144f8.jpeg
We’ve also been discussing storage options, cubby bin sizes, and such.  I made some foam core mockups.  We had an excellent video conference.  Ended up changing things a bit as a result.  It was cool.  Have I told you that the centerboard trunk is 47” long???
IMG_1487.thumb.jpeg.43af91010fe91b8aa1032fa76cd6c8bf.jpegIMG_1488.thumb.jpeg.83e663542c34a60046de7e5f84b8fbac.jpeg
