What would be the minimum allowable temperature for the glue to dry?
Because I am just about going 3D and the dinning room is getting too small for that(beside my wife would eventually say something :lol: )
I have to take building to the garage and the weaterman is calling for 52 to 55 F this weekend. Will this weather affect the glue curing time?
Thanks for the info.
Denis
Denis,
If you are using Dap/Weldwood Urea Resin it is pretty fussy as far as temps are concerned. Really should be above 65 degrees Farenheit. Typically around 70-75 will give the best cure rate.
If it is epoxy, then a faster hardner will probably be satisfactory at 55-60 degrees.
If you have a portable heater, you can tarp over the parts being assembled and keep the heater on in the space and keep the temp up for 12-24 hours to allow it to cure completly. However if it is outside, that is a problem. :lol:
