Hi guys,
I recently finished my 11N.
You can find some pics here:
http://www.rotorman.hu/index.php?page_name=voyage_log&voyage_name=rtrka2
I started to look into masts and sail.
I don't want to spend $800 NZD on a new sail so I started to look at alternatives. Maybe buy a used mast with a used sail? Or maybe an used sail and build the mast myself as recommended by the plan?
What I already figured out is that the Laser Radial mast and sail has very similar dimensions and probably I can get a used mast + sail for a decent price. What do you think?
Are you aware of any other racing class which has similar dimensions?
Or should I try to create (glue) my own sail?
Also how easy is to put on/remove these sails with sleeves? I am thinking of adding some rings to a non sleeved sail and the rings would be put around the mast.
An old Laser sail will work well on a  Spindrift.  That is what I did on a Spindrift 10 years ago and only cut off the lower portion to get the proper area.  It worked well enough to win a lot of races.  Ideal would be a new sail from B&B but when money is tight, why not.  If an old Laser mast is available, use that too.
  • 4 weeks later...
build your own sail. Sailrite may even have a kit sai for your boat.  If not, just get the sail plan from B&B, a book like Marino's "Sailmakers Apprentice", order up the material (Sailrite or Duckworks), score a good used sewing machine (mine is a Snger portable $35 USD), and stick & sew! Jib I built is about 75 sq ft, main about 100 sq ft.
Build your own mast as well. My mast is a 22' birdsmouth construction.
