Upper sections are wooden, Birdsmouth technique, lower 12 feet is 6061-t6. Main wound up weighing 34 pounds with the track on . Mizzen is 25 pounds.l
Charlie,
That boat is beginning to look really good! I am anxious to see pictures of it all together and sailing. I would be willing to bet your customer is salivating in anticipation about now.
Keep up the good work.
Steve
lol- his post is right above yours :lol: We're busting butt to have her ready (at least mostly) by friday morning, THIS week !! :shock:
Laura and I have just put in 4 ten hour days. Four days left, but who's counting :lol:
There must be a million little details to attend to on the home stretch. Hope you make your deadline.
I have yet to see a picture of a Princess that is being driven hard. I hope you have some wind for the maiden voyage!
Charlie, I am ordering a sail from Graham for a project I'm building. It is a 21' Hawaiian outrigger with amas on both sides to make a tri. I am trying to find a tapered section 6061 aluminum tube. I havn't found anything, but I can get straignt sided tubing and mate a tapered birds mouth setion to the top like you have done. What overlap are you using to preserve the strength of the mast? What thickness are you using for the staves of the birdsmouth section? Did you taper the thickness of those as well as the width?
I believe I may try this method as well. Other that asthetics, what are the advantages of the tapered section vs a full length aluminum tubing of the same section?
Dan
