P Doug (WA) Posted September 15, 2004 Posted September 15, 2004 If you put things together using epoxy instead of glue, when you put the screws in, doesn't it squeeze the joint to tight and squeeze out too much epoxy? Or do you use epoxy in that fashion? Quote
Fintan Murphy Posted September 15, 2004 Posted September 15, 2004 Doug, I glued the whole boat together with epoxy, thickened with glue powder and fine sawdust. (from the sander collection bag) I didn't have a problem (yet ), and I think the mixture is thick enough that it doesn't run fully out of the joint. The bit that does run out can be used to cover the screwholes as you go. Quote
Craig Posted September 15, 2004 Posted September 15, 2004 Just don't torque the screws untill all the glue is gone. You want a bit of squeeze out to know the joint is good but not enough to starve it of the epoxy. Is is kind of a expierence thing. You know how much you put in and you can see the amount pushed out. Just play it by ear and know there is a good film in there. Allow for the joint to absorb the epoxy also. If possible paint the mating surfaces with resin and allow to tack up before glueing the joint for final. Quote
Charlie Jones Posted September 16, 2004 Posted September 16, 2004 Craig has given a good answer- nothing really to add. Once you've done a few screws, you'll get the hang of it. Quote
Shine Posted September 16, 2004 Posted September 16, 2004 Ditto, dont squeeze it all out. Same applies if your laminating two pieces together for a transom or stringer. Joel boatbuildercentral.com Quote
P Doug (WA) Posted September 17, 2004 Author Posted September 17, 2004 Thanks all, I will get at it! Quote
Guest Posted September 17, 2004 Posted September 17, 2004 Simple question about epoxy?? LOL Epoxy fillers and fits of the wood, also play a big role in lamination and starvation of a joint. Quote
