musicmanx2 Posted June 21, 2022 Posted June 21, 2022 Now I plan to use Fixwood to fill the area back in and sand etc to make it blend in with the edge. My question is would it be a good idea to put three or four screws across the back edge to give the Fixwood something to grab onto? It's smooth now with the epoxy on it. They don't have to be long screws maybe 1 inch stainless. Anyone use Fixwood from Total Boat. The is a Core Sound 17 and has a bad spot just out under the edge of the splash rail. What do you think guys? Quote
Hirilonde Posted June 23, 2022 Posted June 23, 2022 I would never use any of the so-called penetrating epoxies. You can't fix wood. I would carve out all of the rot, then create a shape that I could fabricate a dutchman for. Then scarf in a piece of compatible wood. If needed I might use a little filler to fair it out. Quote
Scott Pettigrew Posted June 23, 2022 Posted June 23, 2022 I'm with Dave. I would try and replace the wood with a solid piece. I do use penetrating epoxy, but as a pre treatment for new wood. Not to fix rotted wood. Quote
musicmanx2 Posted June 23, 2022 Author Posted June 23, 2022 I dug all the rotten wood out and just hit it with the penetrating to seal the good wood. I thought the fix wood could be used in a project like this. What type of solid wood be good to use for this and how to install the wood after I cut it to shape. Epoxy it in and with stainless screws to anchor it. I guess I would run screws all the way through it to anchor it to the the good wood. I would drill it so not to split the wood. Hmmm I thought this Fixwood from Total Boat epoxy putty would do the job and be strong if I gave it something to anchor to. Has anyone used the Fixwood from Total Boat??????????????????? Quote
