Hi
I'm just starting a CS17 and am nearly finished the side and bottom panels, so next week I'll be working on bulkheads/ transom.
I'll be building an aft cockpit version and wondering if anyone can advise on the best position for an outboard, so that I can fit extra reinforcement to the transom in the right postion. Clearly closer to the centreline is better for motoring/cavitation but gets in the way of the rudder especially on full lock when, on other boats, I've found that the prop can take chunks out of the rudder.
I'm aware of brackets on the rudder box for the motor but don't particularly want to go that route.
Anyone suggest an optimum position?
Peter HK
Thanks for the replies on this and another thread.
I think Ill position it as far out athwartships as possible within the side deck of the aft cockpit version.
Do many people having lifting outboard brackets- unnecessary?
Peter HK
Peter
I considered a lifting bracket also. They are only about $150 new I believe. When not in use, I just tilt my 2 hp clear of the water for sailing, and it does fine. Not in the way. When needed, it is a simple matter to swing the foot down into the water.
