Paint Question
Guest Dave R
Finally, Julie K is getting her bottom painted. I started today but I'm wondering how many coats I should apply. I'm using Behr semi gloss exterior latex.
Anyone? Thanks.
If you are going over glass and a good primer coat then I would suggest that you roll on the first coat and brush it out. Then let it dry for several days and recoat with a second. That should be all you will need. If you are going for a very high gloss then I would wait a week for that second coat to dry and set up completly and then wet sand with 400 and then wash it down and go over it completly with a tack cloth after it dries and then put a final coat on. You can apply a coat of hard wax over that after it has setup for a couple weeks and is pretty well set.
thanks Barry, I should have included that it is over epoxy sanded with a 80 grit. I didn't prime based on advice I got someplace-CRS prevents me from recalling just where.
You should be fine, over epoxy, primer isn't needed. 80 grit leaves a good "tooth" for a good bond.
If you are spraying latex, I would recommend back brushing it immediately with finishing strokes all in one direction. Same with rolling it.
I'd just add that you want to avoid the problem a few of us using exterior latex had: do NOT recoat too soon! Make sure you cannot dent the paint with a fingernail before you recoat. It has to dry HARD between coats.
Latex is much softer, and can take several weeks to fully dry. I coated mine with three coats, a few days apart. It was very soft and fragile for about three weeks. I was worried I was going to have to start over! Mike Donlan had an adhesion problem due to re-coating too soon, with sheets of it coming off the hull.
So take your time ... put a coat on and make sure its hard and dry before putting another coat on. And consider just a single coat if it covered well. A single coat of latex paint is several times thicker than a coat of oil based paint (in general). So you may not need "3 coats" like the guys using that thin, solvent based paint.
Thanks guys. Frank, I hope I don't have any of the problems Mike had. The directions on the can said to recoat in 4 hours so I did put a second coat on. I guess I'll ignore it for a week or so and see what happens.
Maybe I'll get to launch this summer. To think that three years ago, Frank, you gave me a link to your site about the construction of Aslan and now, I'm finally getting close. Thanks a bunch Frank.
Hey Bill, I was thinking about you the other day, too. Have you got your boat out and readied for the water, yet? If you're ever looking for something to do on a Saturday or Sunday afternoon, you're welcome to come down and give me some advice.
:lol:
By the way, the colors we decided on are based on Kirby's paint chips. The hull up to the lower rubrail is 1-Green Gray, the space between the rails and the upper part of the transom is 12-Bottle Green, Rails are 8-See Red. The cabin sides and main bulkhead will be Green Gray (I think) while deck surfaces and seats will be 32-Sand.
Thanks guys. Frank' date=' I hope I don't have any of the problems Mike had. The directions on the can said to recoat in 4 hours so I did put a second coat on. I guess I'll ignore it for a week or so and see what happens.
Maybe I'll get to launch this summer. To think that three years ago, Frank, you gave me a link to your site about the construction of Aslan and now, I'm finally getting close. Thanks a bunch Frank.[/quote']
I was worried with mine that it would never cure. If it passes the "fingernail test" and you can feel that its hard, it should be OK. Mine hasn't had a single problem, except for some mysterious scratches that seem to happen when I get near a dock.
