Finally, after months of screwing around, I finally have the boat at the 3D stage. It's all wired together, and I'll start epoxying as soon as I make a forward bulkhead that fits.
Russ[attachment=1][attachment=2]
   Unfolding the boat is a geat feeling isn't it?
Getting it unfolded without the glassed bottom and side pieces cracking apart is sweet. Took 3 tries before I got it right, thanks to stiff temporary bracing screwed across the joints.
My wife was my helper. I had tried to explain how the flat sheets of odd shaped plywood were going to Morph into a boat, but she wasn't getting it. You should have seen her face when it happened. I believe most folks would have to see it happen with their own eyes before they'd believe it.
Russ
I had read in several posts that sometimes the glass would crack.  Because of that, I used 6" biax 45/45 on the joint and it never even creaked.  I don't know if it would be worth buying it specifically for that, but it worked well in my case.
