davidpm Posted March 30, 2008 Posted March 30, 2008 OK I've got my SD10N cut apart and plan on polishing it up a bit. What it the best process? I'm thinking about using a roller to put on a coat of epoxy then using a spreader to spread on some epoxy with micro-balloons then sand. And do it again. Is that the technique? I have 205 fast hardener. Should I use 207 for coating if is going to be painted? The corners are all a little proud due to the glass tape so I'm wondering how it all gets smoothed out. Quote
Peter HK Posted March 30, 2008 Posted March 30, 2008 OK I've got my SD10N cut apart and plan on polishing it up a bit. The question is how polished. The tapes need to be faired in first with epoxy/sanding filler- see here Quote
Peter HK Posted March 30, 2008 Posted March 30, 2008 Oops Here is the faired tape photo I meant to show inthe previous post Peter HK Quote
