"Imagination" now has running lights. The wiring was substantially improved based on input from forum members. thanks.
Now I am looking for a power supply to run the lights. I am considering one of these portable car jump/DC power supply units. The lights draw just a few watts, so I dont need a huge battery to to deliver a few hours of night sailing. Opinions on these portable power supplies versus deep cycle battery plus charger units?
Brent,
Are you using LED lights? They draw such a low current that you could use most anything for a power.
The biggest problem with any battery that is not used regularly is charging. I know of people who have had one of those jumpers in their car and when they needed it...it was dead too.
Personally I would probably look at a small riding lawn mower battery ($20 at WalMart) and a good on-board charger that you can plug in and continuously charge at home. The newer chargers that monitor and charge (as needed) increase battery life over the ones that continuously trickle-charge. Then just unplug and go without any worries. Make sure you unplug before driving off. LOL.
Joe
I've used a snowmobile battery, about the same size as a lawnmower battery, but with a handy handle. It was only in the boat when I was in it.
If you're going to wire the boat anyway, I'd strongly recommend a fishfinder. They're cheaper than a depth finder and have bigger numbers.
I have a Hummingbird on a small skiff and it's happy with a 6 volt lantern battery. They use very little power.
Gordy
"If at first you don't succeed, skydiving may not be for you."
I happened to see some portable lights in Walmart the other day. They looked somewhat like a large flash light that cliped into a mount. They used several D cells.
Since I like to sleep at night the only time these would be used is if I get where I am going later than planed (likely on a boat without an engine :-)
This is in keeping with the whole objective of my project, which is simplicity. No engine, no electronics, no electrical system.
After considering all perspectives, the answer came to me this afternoon. D cells aint gonna cut it. The agm batteries are great, but way overkill for what I need. For now I am going with a lawn mower battery. When not sailing, I will keep the battery charged by storing it in ...the lawn mower.
