Denis, I made a late decision to return to the wheel sterring system (was planning a tiller from start). Thank goodness I did not permanently attach one of the hull sides. You will find it much easier to set up your rigging going through at least one side versus just an access port. I also omitted the lazerette opening and opted for two deck plates in the corners of the aft deck. Good luck and keep us posted.
Denis,
I installed the Nelson Surbrook steering (and as mentioned before, it works like silk with normal braided 1/4" rope). The blocks, the turnbuckle and the rope (fixed at the end opposite the turnbuckle) were all placed before the hull sides, seat backs and seats etc.
The rope was threaded working through the lazarett standard opening and the end was finally secured by taking it through a borehole in the lazarett wall in the rear end of the below-seat cabinet.
It was difficult, but with some patience it can be done. I would still recommend doing this before closing up the space (for those having a choice), unless plans are to have additional openings to the lazarett.
