The pictures are decieving, as I only pulled the camera out when it was safe to do so. Those pictures were right after a big squal came through. The weather was all over the place as raf as winds went.
While under way, I didn't have any problem going forward. One time I had to lay out onto the sprit to untie the furling line (when we realized it was too short). I think my movements forward concerned others more than it did me. :)
OK, back to furling.....................
Even having to go slightly forward to furl the sail (due to the short line that I cut in the wrong place) it worked quite well.
It is on it's one SS line, slightly aft of the forestay. The 1:1 purchase didn't even come close to overcoming the tension of the forestay. Matter of fact, if I sould set up a 2:1 it would help tension it a bit more, as the luff was a little loose, or so it appeared.
Even with the less tensioned luff, the jib performed very well. I liked the ability to loosen the tansion on the halyard and set the jib as a mock spinnaker. It was really nive to have the added demension of control over teh sail.
We never tried it in the reefing mode (due to the short line), but I fear it wouldn't hold the luff of the sail near tight enough to make it practical.
It only takes seconds to furl the sail, so this is a big plus in numerous situations. I estimate the total cost at about $100 or so ,not counting the cost of having the cable sewn into the luff, as this would probably be done from the beginning if you go this way ($80).
More updates to follow, if of course you are interested. :);) ;)
