SteveH Posted May 10, 2017 Author Posted May 10, 2017 38 minutes ago, NY Dave said: Steve, did you have any problems with the frame at 11'6"? On my plans we found that the notches were cut about a 1/2" too shallow. Dave - just checked my 11'6" frame and yes my notches are too shallow there as well. I hadn't noticed it yet as all my attention was further aft and I haven't cut the stringers into the bow yet so they're all sticking out a bit. But yes it appears they need to be cut in a bit. Decided to look at all the others and the 5' 4" looks a bit shallow too. As far as the keelson is concerned I think the step in the 4'4.5" bracket is too high, if it was cut down a bit it would allow the keel to full into a fair curve. Also, with the 7' frame being too narrow I was going to cut the frame and extend both pieces out to meet the gunwales and rejoin the frame like a splint on a broken leg (with epoxy and ply) however, my neighbour has just come up with a good idea - leave the frame in place and glue in some short doublers out between the gunwale/stringer and the frame to take up the slack instead. Jeff - have I been sold some old plans? Quote
Kudzu Posted May 10, 2017 Posted May 10, 2017 No, you have the current plans, I print them when ordered. 11' 6" frame was changed. There is a revision mark on the plans for that. My suggestion is just stop and give me some time to look at this. I will make it right. Once I get orders out this morning, I am going to start from the beginning and fully review the plans. It may be time to update Curlew. It may take me a couple of days but just be patient. Curlew was my first commercial design. It has had some minor changes made over the years but I have not given it a thorough looking over in several years. Let me look it over and see what is wrong and then we can go from there. Quote
SteveH Posted May 10, 2017 Author Posted May 10, 2017 4 hours ago, Kudzu said: No, you have the current plans, I print them when ordered. 11' 6" frame was changed. Well that's the reason I ask - as my 11'6" frames appears to have been not changed i.e. The gunwales appear to need to be cut in further. But yes I have stopped and will wait for your advice before cutting any more wood. Quote
Kudzu Posted May 10, 2017 Posted May 10, 2017 Found out what was going on. First, the original 3D model of the boat was lost. I have changed software and somewhere along the line Curlew was lost and not imported. All I had was some other versions I looked at but never used. Took some doing but I did find an old copy and finally managed to get it converted and it into my new software. I went through everything to see what was going on. I found two problems and one thing I want to change. Two frames are wrong. 11'-6" is all out of whack. No idea how it got this way but if I knew how to prevent mistakes I would be a rich man. It is causing a lot of the problems, Frame 7' 0" ?? (I am tired) was wrong so I corrected it. I see what happened on the coaming but no idea why it was undersized. I decided to move the bracket at .... 4' 4" (I think it was) to the next frame at 5' 4" , Steven you can trim your existing one and it will not effect you Dave. I have two copies of the corrected frames and bracket printed out on my drawing board. Send me a message with your addresses and I will get those in the mail in the morning. I have stared at these monitors so long my eyes hurt, so I going to have some fun. Quote
NY Dave Posted May 10, 2017 Posted May 10, 2017 Thanks Jeff. I sent you a message with my address. I look forward to getting the corrected frames. Not really looking forward to more lashing though... Quote
coherent-rambling Posted May 30, 2017 Posted May 30, 2017 I bought a Curlew frame kit back in late 2013, but life got in the way and I have just now gotten ready to build it. I was skimming forums for tips before I got started, and think maybe I was lucky to stumble across this topic. What changes will I need to make while I'm building my boat? Thanks! Quote
Kudzu Posted May 30, 2017 Posted May 30, 2017 Any chance you still have your order number? If not send me an email with name and address and I can find it. We will start the process and get this corrected. Quote
coherent-rambling Posted June 1, 2017 Posted June 1, 2017 Against all odds, I was able to find the order number. 1386370912-685. Thanks for the quick response! Quote
Kudzu Posted June 1, 2017 Posted June 1, 2017 Found your order and will be sending you an email concerning the fix on this. Quote
