  • 2 months later...
Update time, we have sailed Southern Express some and getting used to a boat this light! It is a pleasure to sail!
Alan cut us some trail boards for our registration numbers. Wanted to show them off a bit. They "should" go above the rub rail but we have the spinnaker pole socket that prevents that, so I installed them below.
All my pics through out the build were sideways or upside down, hope these look ok!
Doing a rethink on the main hatch. The pop up hatch has too many compromises under sail. The sliding forward hatch is working out fine. Pics as it becomes " photographable "
  • 3 months later...
Jay, she looks great sitting on the beach. Not that I am anywhere close to needing the info, but on Southern Express you have the forward hatch right behind the mast. How is it working there? Also, I notices sort of a protective piece on the bow stem. I like it. What's it made of?
Hi Steve, the forward hatch works pretty good, I can raise the mast on deck and reach through the opened ( gotta unlock it first!) and spin the mast nut down. In bumpy water, we stand in the open hatch to work the main mast and anchor. Alan designed a cool reefing system so we don't have to go forward often after the sail is hanked on. Also works good with a wind scoop on the main halyard. The stuff on the bow is a local stuff called "Gator Guard". Handy for trailering, and we have a lot of tanin in our fresh water, this helps getting the mustache on the bow of tanin stains. Not wild about the looks, but....
  • 6 years later...
Well Southern Express, our beloved Core Sound 20.3 is almost 7 years old, and we calculated about 2000 nm in the water and a heck of a lot more on the trailer, Southern Express is getting some love.  A repaint, and some electrical upgrades.  Darn lifepo4 batteries are so light and relatively inexpensive, we will be upgrading to a 50 amp hr lithium battery.  Might upgrade the cushions.  Moving the centerboard and adding length to the board?  Still thinking bout dat!
  • Like 3
I thought the c/b location thing was limited to the first few 17’s.  (I always reserve the right to be wrong.)
It is interesting to me to see your new stem and that 1” high keel.  Has that always been there?
Jay, I thought Southern Express went to another person just before Messabout.
It really is a nice looking boat.  Spending some time aboard Southern Express with you guys in 2021 is primary to my decision to snap up Avocet when it popped up for sale… so thank you.
Jay, I remember during the building of Skeena getting on Southern Express at the Messabout. It kept me focused.  Like you, I am thinking about moving my CB forward. I'll start there and then maybe later lenghten, although I don't think she slips sideways much. I'm going to write my thoughts on my thread.
Thanks,
Steve
Started sanding the boat today, never was happy with the finish on the cabin sides, I am priming it with a nice coat of Awlgrip 545 primer, then practice building my chest muscles with everybody’s favorite longboard.
 Fresh plexiglass ports just to refresh the look.  The bonding the plexiglass with VHB tape has been a success (except where I didn’t get the tape ends touching and we had minor port leaks till I figured it out.
I am possibly not astute enough sailor to tell if the centerboard needs to move forward a bit, we have lots of time that the boat was balanced and we were hands off… can’t see it being any better.
Don, initially when the boat was inverted we clamped tape coved 1X4s on both sides of the keel then added epoxy with graphite thicken epoxy to about 3/8 to 1/2 inch thick.  I had problems with our 2 paws with the screws working on the keel strip and allowing water into the wood.  Well as some can attest, we have beached the boat both intentionally (and unintentionally )  the keel is in almost perfect condition despite my abuse.  I am going to open the centerboard slot slightly and reglass the slot, it always had a tendency to stick in the up position when I add mud to the board.
When I added the solar panels the MPPT controller wasn’t readily available, and quite expensive.  The plan is to replace the solar controller with a more efficient controller and a 50 amp hour lithium battery.  We are totally impressed with the solar system on Kalos and going to build a miniature system on Southern Express.
Carol has made it perfectly clear to me that Southern Express is our family boat….long term!
Southern Express is a fine boat.  Happy that Carol put her foot down.
With Avocet, no matter what trick I tried, she would always veer OFF-wind, if I let go of the helm.  This is dangerous.  Besides, it’s difficult to tack, when the tiller is already halfway over.  And the boat is slower, too.  I think this is the reason that the previous owner had a reef in only the main in this photo.  That is the one trick I did not try.
