couple of questions.
for someone of average height, would the gunwhale fall at or above the knee when standing against it fishing?
are you able to give an indication of how many hours a small commercial yard might take to build it?
many thanks
marcus
G'day Marcus,
Thanks for enquirying about the Edge Tracker.
In regards to the vertical height, the distance from the sole to the side deck (vertical height) for Edgetracker 426 is 595mm or 1ft -11.5in.
The Edge tacker 487 (16ft) is 2ft 1.25in ( 641mm)
The edge tracker 548 (18ft) is 2ft 4in (711mm)
To build the edgetracker 426 should take approx 2 weeks to build, however this would not be full time as a lot of your time, your just sitting around waiting for the epoxy to cure before beginning the next stage. As an example, we took 2 weeks to build the Mushulu 14, working on average 3-4 hours per day.
Building the edge Tracker is pretty easy (like all our designs) as all the components or parts are given with measurements and they're also nested onto plywood sheets to help save on wastage
Hope this helps
