Spindrift 12 #1275 - Mast Length
J. Cote
When I laid out my Mast sections with 9" bearing overlaps, I was 3" longer than the plans (233" vs 230" design).
I figured out that my top section is 3'-8" instead of  the 3'-5" design.
My inclination is to keep the extra 3" (heck - more head room from the boom.....right?)  But I don't want to assume that is OK and regret it later when I try to rig the sail, lines & hardware, try sailing it, etc.
If the answer is to stick with the plan length, I could either trim the top section to plan length or make 10" bearing overlaps.
Recommendations?
16 hours ago, Hirilonde said:
It will add healing force to the boat.  This will also make the boat slower as the wind picks up.  I never find the head room an issue and I always liked going as fast as possible.  To each his/her own.
Wow! You just made me realize that my "layman's logic" is interfering with Graham's intricately calculated design.
I had to look up "heal force"........ https://en.wikipedia.org/wiki/Forces_on_sails
I haven't studied forces, vectors, velocity, speed, etc... in decades.  This web page is going to take a few revisits from me before I totally "get it".
Bottom line:  Don't "F" with Graham's design. ??
Hi Jan,
Can you hold off on the mast until I check the shop computer tomorrow. I was under the impression that the S12 mast plan was updated. My home computer is showing a mast that I updated in 09. We have gotten rid of the wood mast heel plug and replaced it with a plastic heel which changes the length of the aluminum sections.
We're talking about 3 inches here so it won't make a lot of difference to the heeling moment. You can always not hoist the sail the last 3 inches and it will be as designed. In theory in light airs it may be beneficial to get a little higher above the boundary layer into a stronger breeze - but we're only talking 3 inches.
As to adding a healing force I'd do anything for that these days with the arthritis in my hand, back and shoulder?
Cheers
Peter HK
22 hours ago, Graham said:
Hi Jan,
I think you found the 3" explanation, Graham.
My plans show a wood plug 6" long with 3" in the tube, 3" out.  Alan shipped me the plastic plugs (top & bottom) so I can visually understand their impact on length now.  My plans also show a wood upper section. I was pleasantly surprised to find an aluminum upper section in the kit.
However, on the plans, the 230" total length appears to visually include the wood heel plug (of +3").
We have gotten into similar discussions before. Another one is the weight of adding glass sheathing to boats that don't require it.  What is a lot?  What is too much?  I want all of of my boats to be as fast and light weight as possible.  For me, anything is a lot. I can plane my Lapwing and Spindrift solo. I wouldn't sacrifice any ability to do that for anything.
Damned because it is all related.
