Pete McCrary Posted August 16, 2020 Author Report Posted August 16, 2020 Thanks Graham. You probably told me that back in 2016. Quote
Pete McCrary Posted August 16, 2020 Author Report Posted August 16, 2020 Got a lot done today. Rudder assembly ready for glueing. Three inch FG tape epoxied to both sides of each puzzle joint — and weave filled. After an overnight cure the panels were adjusted so that the inboard sides laid face-to-face, continued the keel bevel from the bottom edges right up the stem. With all holes lined up, loosely wired the keel edges together. Then stood it all up to make room for the cradle. Tomorrow the cradle will be fine tuned and screwed to the floor. Mr granddaughter and her fiancé (Kate & Corey) will arrive on Friday to assist in the transition from butterfly to Seabiscuit. A fine excuse for a family celebration! In the meantime I’ll work on other components and making the trailer ready. Quote
Pete McCrary Posted August 23, 2020 Author Report Posted August 23, 2020 Well, ... after about three days curing (the puzzle joints), Corey (my future grandson-in-law) and I transformed a stack of flat plywood into the shape of a fine-looking boat. Here we are just getting started with granddaughter Kate recording. Corey and I started the process. Fwd and temporary bulkheads dry-fitted. Corey doing the hard work — tightening up the loosely wired keel. Fore and aft views. Temporary bulkhead set with side planks just 1/16” proud on each side. Side-to-side transom top almost parallel with top of temporary bulkhead — maybe port-side of transom 1/16” high? Note that the chine cable-ties have not yet been tightened up. We’ll take another look when transom is in place and everything tight. Same view from aft might look a little better. Next will be trimming the transom’s bevels and dry-fitting it to the hull. Quote
Pete McCrary Posted August 29, 2020 Author Report Posted August 29, 2020 Originally I ripped a pair of 1-piece gunwales (Douglas fir) — but they were much too stiff to dry-fit to the sheer. So, using those pieces, I ripped two 1/4” strips (wasting the middle third) and bought 1/4” x 1.5” [flat] moldings (clear white pine) for the middle strips. Shown here are the assembled strips dry-fitted to the sheers. Next cooler day, they’ll be glued to the sheers. Anticipating some considerable stress on the stem and transom joints, I made strong tac welds. Tac welds at the transom. Next I fabricated the rudder pivot-bolt so that its “clamping force” could be adjusted without any tools. The “handle-nut” need only be rotated 3/4 - turn for full “tight” to “loose.” The carriage bolt is held tight by a 1/4” plywood “washer” shaped like B & B’s scalloped diamond. Note that the “single-wing-nur” need not be a lock-nut due to its imbalance on a [mostly] horizontal shaft. The other side. Quote
Pete McCrary Posted September 1, 2020 Author Report Posted September 1, 2020 Major milestone reached — gunwales installed. And she’s just about ready for tac-welding. When dry-fitting I managed to trim the gunwale foreword ends for a nice joint. That sharp point will be rounded to spread stresses caused by encounters with docks, other boats, et cetera. Quote
Hirilonde Posted September 2, 2020 Report Posted September 2, 2020 I cut the bow end of the gunwales square to the center line just shy of the hull, then rounded. Made it really blunt. I did no tack welds. I went right to filet and heated the wires to pull them from the epoxy. Saves a step. Getting there. Quote
Pete McCrary Posted September 13, 2020 Author Report Posted September 13, 2020 To get her DWL level, I had to raise the fwd cradle 3/4”. Used a mason’s string level. Rounded the fwd rub-rail. Note taut string. Getting her ready for filleting. Seat tops now joined. Quote
Pete McCrary Posted September 16, 2020 Author Report Posted September 16, 2020 Dry-fitting seat supports. The long outboard cleats need some “persuading” in order to conform to the extra bending of the side panels near the bow. And also along their entire length. The inboard seat supports also needed to be pushed outward to so as to be just under the seats’ edges. My plan is to round over the seat edges to a radius of 3/8”. Glue outboard seat supports tomorrow — inboards next day. For gluing (Seat supports) the seat tops wI’ll be removed until the CB trunk has been fully assembled and permanently glued in place. Quote
Chick Ludwig Posted September 18, 2020 Report Posted September 18, 2020 Sometimes these dang things just don't quite seem to fit like they should. Here's my advice. DON'T force it! Get a BIGGER hammer! Quote
Cmackg Posted September 19, 2020 Report Posted September 19, 2020 Pete - just realized you’re nearby - I live by Leesburg, and built my Spin 10 this spring. Might have to visit with you! Here’s Puddle Duck after a long beat upwind on out local reservoir. The down hill ride was much easier. Quote
Pete McCrary Posted September 19, 2020 Author Report Posted September 19, 2020 Looks like Puddle Duck has a very nice sailing pond. You’re lucky they allow sailing on the reservoir. Please come and visit. We’re nearly always here. Just email pkmccrary@verizon.net so we won’t be out-‘n-about. Here are two more photos of Seabiscuit progress. Glueing the inboard seat cleats. Third coat of epoxy on the insides of the CB trunk w/Kingposts being glued on. Quote
Pete McCrary Posted September 22, 2020 Author Report Posted September 22, 2020 CB Trunk’s base has been trimmed to fit the slight v-bottom — and tac-welded in place. Proper filleting and FG tape to follow. Earlier the foredeck framework, quarter knees, and more seat cleats were glued in place. And finally, the Bresthook and bow-reinforcement block were installed. Both have 1/2” holes drilled thru. With a bowline loop and a “stop-knot” — one line can serve as a bow-“eye” and painter as shown here. Turnover is scheduled for Saturday! Quote
Pete McCrary Posted September 27, 2020 Author Report Posted September 27, 2020 Graham may be glad to know that her weight (measured at ~ 89.5 lbs) is right in line at the high-end of his design estimate. Configuration: outside surfaces bare, all interior flotation spaces & corners filleted, taped and triple-coated with neat epoxy; gunwales, foredeck, breasthook & quarter knees glued in place; and CB trunk glued in place, filleted, and taped. Seat tops attached (dry-fitted). CB Trunk filleted, glassed,.. firmly in place. Seat tops dry-fitted. There will be dry-wall screws between the weights. A Taylor “spring” scale — 220 lbs max. Accuracy +/- ?? lbs. Seabiscuit suspended by her Bow “bowline” loop. The pound scale set at zero (pretty close). I called that 89.5 lbs. Maybe 89.75? We took this occasion to “dry-fit” Seabiscuit to trailer. Must raise roller 1”. Now she’s ready for bottom work. We celebrated by treating Jim and Patricia to lunch. I’ll begin bottom work tomorrow. My plan is to launch her maiden voyage at the Messabout. Hope to see some of you then. Quote
Pete McCrary Posted October 2, 2020 Author Report Posted October 2, 2020 The bottom plywood edges all now have nice 3/8” radiuses and she’s ready for all epoxy and FG work. But today, taking a break, I dryfitted the gooseneck and cheek block to the boom. Should’ve been 1/4 hour job, but Racelite made it into a two hour job. The cheek block is to be mounted on the starboard side of the gooseneck using two of the [gooseneck] holes and drilling a new hole replacing the third bolthole (from fwd end of gooseneck). However, with that done, the sheave shaft didn’t lineup with the gooseneck’s second bolt hole by about a half-hole width. Ever try to drill a half hole?! It’s near impossible. So, I didn’t. There was space enough to use the gooseneck bolt hole and instead of a bolt, I just used a bolt shaft and captured it with a small piece of hollowback half oval. Starboard side. Locky there was enough space for the sheave to freely rotate when repositioned. The other side showing the SS half oval retainer. Quote
AmosSwogger Posted October 6, 2020 Report Posted October 6, 2020 Nice work Pete. I like your boat weighing method. Quote
Pete McCrary Posted October 6, 2020 Author Report Posted October 6, 2020 Amos, I’ve found that esigners’ weight estimates are often on the low side. But Graham’s was right on! I’m trying to keep Seabiscuit’s weight down so that I can man-handle it without always asking for help. The Messabout is just a little over two weeks away. Not sure if I can have her ready by then. Maybe only with her bottom covered with a primer. We’ll see. Today the CB slot will be routed out, dressed, and glassed. Here are the latest photos: The roller had to be raised one inch in order to get the bottom higher than the lowest adjustment for the bunks. Trailer is now ready for boat-to-bunk adjustments. Quote
Pete McCrary Posted October 12, 2020 Author Report Posted October 12, 2020 Moving right along. I’m feeling like Seabiscuit should be ready for a road trip the end of next week — with two coats of 545 Awl Grip primer on her bottom and all rigging in place and interior with 3 coats of neat epoxy and seat tops glued down. Here are some recent photos. CB slot routed out. Keel glued on. First coat of primer. Second coat to be applied tomorrow — no sanding needed. Both sets of mast bushings completed. I had a section of a 2” dowel left over from a project. Just the thing for the “plug” needed at the mast heel. Just three wraps of FG needed to make a snug fit. Annie is of Polish ancestry — and when seeing this photo her niece said “A pole holding a pole.” The mast weighs just 8.75 pounds. Nice and straight, isn’t it? Quote
Pete McCrary Posted October 14, 2020 Author Report Posted October 14, 2020 The gooseneck bracket has been attached to the mast with thickened epoxy and four wraps of 3” FG tape. Next I was planning to install the cheek block at the mast head — but I realized that would prevent the top mast section from “nesting” with the two other [larger] sections. So, I thought up this solution. The double “bull’s eye” was cut from a scrap 3/4” marine ply. The pulley is an RF-20101 ball bearing. Installed with a thru-bolt into the masthead plug. All three nested together. The profile of the cheek-block [installed] was too large for the space available between the ID of the 2” tube and the OD of the 1.5” masthead tube (difference ~< 1/4”). Seabiscuit will be turned over this afternoon. I’m pretty sure she’ll be at the Messabout next week. 1 Quote
Pete McCrary Posted October 20, 2020 Author Report Posted October 20, 2020 Although she will be in her underwear, Seabiscuit will be at the Messabout and submit to a shakedown cruise. This morning she was fitted to her trailer and in the afternoon a dress rehearsal and a “dry” fitting of sails, rigging, etc. Everything fit ok, but some trimming will make it better. An x3 pulley lifted her off the cradle and onto trailer. Passed the driveway exit test without dragging the skeg. Mast stepped and painter coiled on foredeck. Halyard, reefing line, and boom vang tensioner. CB held up with bungee cord and pvc. Controls at the helm. Ready for sailing. Mainsheet coiled over swivel cleat. While trailering, rudder assembly will be stowed within the boat. Out haul and reefing line. Dry fitted, but definitely not “road ready.” Reefing line at the luff. See you all on Friday. 1 Quote
