Princess Sharpie 22 Trailer
Guest Greg Luckett
Guest Graham Byrnes
The trailer is not discussed in the plans at this point in time, however, if there is a need we will add it to the plans. The CG is shown in the plans and as you will need about 10% tongue weight. Starting with the CG just forward of the axle you can tweak it till you get the right tongue weight. Trailing weight should be around 1500# so you only need a single axle trailer.
As there are many trailers out there which are suitable, we would not make a specific recommendation as availability is varied around the country and even more so for our overseas builders.
