Sign in to follow this
tfrei
water in CS17 mast
Hi.  I just took my CS17 out of the water up here in Minnesota.  I noticed that the mizzen mast had a fair amount of water in it.  What do you think is the best way to get all the water out?  My first thought was to just drill a 1/4 inch hole in the bottom wooden plug, drain out the water, and then plug it back up with  something.  What do you think?
Anyway, that's what I did.  Just drilled a whole into the bottom plug and all the water drained out. I'm not sure why I thought that was so complicated.
You said you would plug it back up with something- I wouldn't do that as the water will just re-accumulate. Best to have a permanent drain hole.
My 2c worth
Cheers
Peter HK
All masts ned a weep hole or two. Leave it open, so condensation can escape. Any enclosed space will cause condensation to collect inside it, so it needs to have an escape route.
  • Similar Content
    • By greendane
      Hi--a long shot, but thought I would ask. Looking for aluminum masts for my Core Sound 17. Short story is the one I bought had wood, square, hollow but badly damaged. Wanting to retrofit to aluminum. More interested in sailing than building so looking for a pair within about 300 miles of Seattle area.
