Dutchman Posted February 21, 2016 Report Share Posted February 21, 2016 I had been looking at building a stitch & glue until I came across the Kudzu SOF website and am quite interested in building a SOF kayak. I am 6'-3", 220 lbs and 66 years old. The Curlew looks interesting but not sure it will fit me and my size 13 feet. I also would like to be able to pull my legs out while seated and wondered if the cockpit can be lengthened to about 42". (I had a chance to sit in a Pygmy Pinguino 145 with a 36" cockpit and could not get my legs out.) Thanks for any input. Quote Link to comment Share on other sites More sharing options...
Abyssdncr Posted February 21, 2016 Report Share Posted February 21, 2016 Having stalled out a couple times on my S&G CLC Wood Duck Double, the SOF build style is way more fun and faster. That said, if you have to go S&G, check out the roomier Wood Duck series. I'm about* to finish up my FreeB which has a very roomy cockpit, even for me at 6'5". You might take a look at the Mess About series as well if ease of entry is of primary concern. Quote Link to comment Share on other sites More sharing options...
Kudzu Posted February 22, 2016 Report Share Posted February 22, 2016 Cockpit length is only half of the equation. The height at under the coaming is a big factor. I am working on redesigning the boats to use a laminated frame this gives more space. I am trying for 11.5 to 12 inches clearance as I redesign the existing boats. Now to your question, no, you can not alter the boat to add a longer cockpit. Plus I doubt size 13 feet will fit a Curlew comfortably. You will would need to look at another boat. The gunwales on the Curlew are pretty low and there isn't much 'toe' room. If I had that boat to do over I would raise the sheet line a little bit. Quote Link to comment Share on other sites More sharing options...
Dutchman Posted February 22, 2016 Author Report Share Posted February 22, 2016 Thanks for the feedback. Sounds like I should be considering the Messabouts to accommodate easier entry and exit. What is the width and approximate weight of the 12' version? I was also wondering if Kudzu might be displaying at the Michigan Quiet Water Symposium or the Canoecopia event in Madison, WI next month? It would be nice to see the kayaks in person. Quote Link to comment Share on other sites More sharing options...
Kudzu Posted February 22, 2016 Report Share Posted February 22, 2016 We went last year but it is just to far for us for a one day event so we probably will not do that one again, unless we decide to do Canoecopia sometime. Quote Link to comment Share on other sites More sharing options...
Dutchman Posted February 23, 2016 Author Report Share Posted February 23, 2016 Jeff - Thanks for the quick response. If you could still give me the width & weight of the 12' Messabouts, I would appreciate it. Any opinion on which of your boats is best for a larger paddler? Looks like you have a great product and hope I can make something work. Quote Link to comment Share on other sites More sharing options...
Kudzu Posted February 23, 2016 Report Share Posted February 23, 2016 I really don't remember the width on that boat and i don't have it in front of me either. As for which boat, it's really hard to say. Shad is pretty small but other than that any of them have a high weight capacity and reasonably roomy inside. Vardo is the highest volume. But so much depends on the personal preferences it is really hard to say. Quote Link to comment Share on other sites More sharing options...
