mcdermitt Posted June 24, 2015 Report Share Posted June 24, 2015 I was planning on using a 3 hp light weight Johnson on my boat but I have a compression problem so I my have to reinvest ina different motor . I can not afford a new one so I am going onthe hunt wrong time of year to look for one. I may be able toget a Suzuki 6 hp but it is heavy (2 cycle) fo a reasonable price but I wonder about weight thanksk Quote Link to comment Share on other sites More sharing options...
PAR Posted June 25, 2015 Report Share Posted June 25, 2015 I always recommend an engine with FNR capabilities. These are typically 5 HP and up, but the convenience of being able to shift on the fly overwhelms the weight. The CS-17 can handle the weight easily, though only needs a few HP to putter around just fine. Quote Link to comment Share on other sites More sharing options...
Ken_Potts Posted June 25, 2015 Report Share Posted June 25, 2015 I think weight is more important than horsepower. I always found that my 28lb 2hp Honda had sufficient power for my CS17 and although it lacks a reverse gear it is easy to spin around 180 degrees to reverse the thrust. Hanging even a little more weight off the transom has a big effect on trim because the weight is so far from the center of bouyancy. Lots of people have used heavier motors and been happy with them, though. When it comes down to it, anything that gets you on the water is a good thing. Quote Link to comment Share on other sites More sharing options...
