mfrankel Posted May 27, 2015 Report Share Posted May 27, 2015 Any suggestions for a spray skirt that fits well? Quote Link to comment Share on other sites More sharing options...
Kudzu Posted May 27, 2015 Report Share Posted May 27, 2015 Maybe a Snap Dragon large (deck). Just got to try one on the Short Shot and it fit perfect. Shape is a little different but I suspect it will fit both. If you are looking for a nylon touring skirt, New Harmony large work well on both. Quote Link to comment Share on other sites More sharing options...
Action Tiger Posted May 27, 2015 Report Share Posted May 27, 2015 I have a pattern to make one any size, if anyone's interested. Quote Link to comment Share on other sites More sharing options...
andy00 Posted May 27, 2015 Report Share Posted May 27, 2015 For my Ravenswood, I purchased a custom skirt from Seals (sealsskirts.com). It is an Adventurer nylon model; but, I believe that you can order any of their models. I had to order it thru the local retailer (Campmor, in this case), as Seals does not sell directly to the public. I sent a tracing of the coaming to Seals. It cost the same as the Seals pre-sized skirt and fits perfectly. Fair winds, Andy Quote Link to comment Share on other sites More sharing options...
Action Tiger Posted May 27, 2015 Report Share Posted May 27, 2015 I meant a pattern to make your own. Get some coated nylon and sew, man, sew... Quote Link to comment Share on other sites More sharing options...
Kudzu Posted May 28, 2015 Report Share Posted May 28, 2015 I heard at one of the shows that Seals assigns a number to any special orders and you can order one by that number. I don't know that for fact, but Seals does make a good product. Quote Link to comment Share on other sites More sharing options...
Action Tiger Posted May 29, 2015 Report Share Posted May 29, 2015 Okay. Basically it goes like this. You measure the circumference of your coaming. Then the circumference of your chest about sternum level. Tie a string around your torso about where you measured. Then, sit in your boat and measure from the back of the coaming to the string tied around your chest. Lean WAY back and measure from the front of the coaming to the same string, but in the front. Do a little math, draw some curves, make some seam allowances, make a pattern and cut it out. Trace the pattern onto a piece of folded coated nylon, and stitch up the front. Fold over and stitch drawstring tubes at the top and bottom, feed the drawstrings through and toggle them, sew on some webbing with buckles to attach the suspender straps, which you also make with nylon web and buckles. Takes an hour or two and costs for materials are pretty low. Everyone here knows how hard sewing really isn't after all, right? Quote Link to comment Share on other sites More sharing options...
