stevebf Posted February 22, 2015 Report Share Posted February 22, 2015 Hello all. I am new to this forum and have been building my first strip canoe, a Prospector design being assembled on a strong back I made with wheels to roll around the garage. I think my approach is a bit different since I ripped 1/4" strips from discarded, 12' long, clear cherry scrap, scarfed pieces together to make 18' long strips and then edged each with a bead and cove. I also found some discarded mahogany, black walnut, maple that I used to make a decorative accent strip that I glued together with T88 epoxy and then added bead and cove edging. So the hull is closed in and I am in the process of scraping, planing with spokeshave and sanding. Question - Since I started with 1/4" strips the hull seems awfully thin. Is this normal or did I make a mistake? Will the epoxy-fiberglass add the needed rigidity and strength? Does anyone have any recommendations on the best fiberglass, epoxy to use? Materials that will hopefully give a newbie a nice professional finish? What company would you recommend? Thank you in advance. Quote Link to comment Share on other sites More sharing options...
Rich D Posted March 20, 2015 Report Share Posted March 20, 2015 Unless you had to do really excessive sanding to get your boat smooth your 1/4" strips will not be too thin. The cloth on both sides will provide lots of strength. One of the kit and plan providers even recommends 3/16" strips. There are lots of suppliers for cloth and epoxy. I have used RAKA on lots of boats with good results. Quote Link to comment Share on other sites More sharing options...
