meester Posted October 7, 2014 Report Share Posted October 7, 2014 HI All, I've been lurking on the forum for a while, enjoying your posts and I figure it's time for me to speak up. I have just ordered plans for the CS 15. It looks like a great boat, and the build videos that Alan S has been posting are about the best I have seen anywhere. How can I go wrong? I'd like to pose a question, and I haven't seen anyone write about it before, so here goes. I came across these videos of the CS 15 in action: The "white boat": The "red boat": If I listen carefully through the classy music in the "red" video, I hear the wind and a rushing sound from the hull. In comparison, the hull in the "white" video makes a "pinging" sound against the ripple. With my eyes closed, I might have guessed the white boat was aluminum. So, now here comes the question: Do different boats from the same plans actually have different sounds, and if so, what is the difference in the build? Thanks in advance for your comments. Bob "meester" McMichael BTW, these vids and others are collected at http://boatplans.cc/b-b-yacht-designs/core-sound-15. Quote Link to comment Share on other sites More sharing options...
Howard Posted October 8, 2014 Report Share Posted October 8, 2014 Bob: I doubt it has anything to do with the boats. More likely, how the boat was loaded (lockers empty), video device being used to record with, camera position, etc. The only thing I can think of that might matter if one was glassed and one wasn't. I know if I glass a panel, then tap it, it has sort of a "ring" to it vs. one that is only epoxy coated. One thing that plagues most videos of moving boats is the wind noise. Wind rushing past the built in mic gives that awful static noise. Not sure how to eliminate that. I once saw an NPR reporter do an outside interview with a hand held mic and she put this large, fuzzy sock over it. I assume that was to eliminate the static noise of the wind. Not sure if the same thing is available for the small cameras and video cameras we tend to use. Quote Link to comment Share on other sites More sharing options...
meester Posted October 8, 2014 Author Report Share Posted October 8, 2014 Howard, Thanks for the tip about the sound of glassed vs. coated panels. Just the kind of wisdom I'm looking for. I also wonder about how non-skid treatments or different paints might affect the sound. Quote Link to comment Share on other sites More sharing options...
Dnjost Posted October 8, 2014 Report Share Posted October 8, 2014 Yes. a windscreen is available for most good handheld recorders. It is essential for outdoor work. I use one that looks like a bad toupee on my recording gear when working outdoors. I was thinking that upwind always sounds different than downwind. Quote Link to comment Share on other sites More sharing options...
David M Posted October 9, 2014 Report Share Posted October 9, 2014 Did anyone else notice that the foot of the mizzen on the red boat was fluttering on starboard tacks but not on port tacks. Any ideas on trimming to correct that? Quote Link to comment Share on other sites More sharing options...
