uncleralph Posted July 13, 2012 Report Share Posted July 13, 2012 Jeff, I have the Ravenswood plans and I have read your book. In the book, you make the coaming from 3/4 in. and 1-1/8 in. rings. The plans have 1 in. and 1-1/2 in. rings. I assume there is reason you changed. Did the dimensions in the book prove inadequate? The scantlings on the plans seem really hefty, but I have never built a SOF boat. I calculate a coaming built to the plan dimensions from marine fir will way almost 3 1/2 pounds. Built to the book dimensions, almost a pound less. I realize you advocate the laminated coaming, but I like the simplicity of the plywood coaming and I have the plywood anyway. Would you anticipate a problem if I built the coaming per the book scantlings. Thanks, Ralph Quote Link to comment Share on other sites More sharing options...
Kudzu Posted July 13, 2012 Report Share Posted July 13, 2012 Actually the book came out after the plans. The smaller coaming is a result of experience. I just have learned building boats that they didn't have to be so big The plans still reflect the wider coamings and honestly I had not noticed that. Some of the new plans may have the narrower dimensions, I don't know but it is something I will have to look into. I didn't think the coaming was anywhere near your calculations so I took my scales to the shop and measured an old one with the screws that came off a boat I reskinned. 3 lbs with the screws. I am impressed with your calculations! Quote Link to comment Share on other sites More sharing options...
uncleralph Posted July 14, 2012 Author Report Share Posted July 14, 2012 Thank you, I will go with the dimensions from the book. I mistakenly assumed the plans had the latest dimensions. As far as the weight calculations - In a previous life I was an Aerospace Engineer, so weight calculations are sort ingrained in me. Ralph Quote Link to comment Share on other sites More sharing options...
