bollard or cleat for CS17
#1
Posted 02 July 2012 - 09:08 AM
Joe
#2
Posted 02 July 2012 - 12:52 PM
To thru-bolt it, I drilled and epoxy sealed the holes from above, then had my wife slip down through the forward hatch, wipe away any excess sealant, then slide on each washer, and hold a wrench on each hex-nut while I tightened from above. Since this can be a high-load area, I overdrilled the mounting holes, re-filled them with thickened epoxy, then drilled the correct (smaller) diameter holes. This forms an epoxy bushing so the bolts don't directly contact the surrounding plywood.
The only thing I don't like about this cleat location is that it only barely allows clearance for the anchor shaft on my small (4 lbs.) Fortress danforth anchor. If I were doing it over, I would set it slightly further aft to give a little more clearance behind the bow roller. Can't go much further back, though, or you run into the main mast.
Wes Kisting
Core Sound #102 "Second Wind"
#3
Posted 02 July 2012 - 01:47 PM
joe
#4
Posted 02 July 2012 - 04:52 PM
#5
Posted 02 July 2012 - 05:31 PM
Wes Kisting
#6
Posted 03 July 2012 - 04:25 AM
#7
Posted 03 July 2012 - 05:32 AM
Not having any access at all to that area is a bad idea.
I hate hate hate that my boat does not have a hatch on the front deck. When it cools off, I plan to refinish and repaint my boat along with adding a hatch in the front deck.
#8
Posted 03 July 2012 - 02:45 PM
#9
Posted 03 July 2012 - 03:15 PM
#10
Posted 03 July 2012 - 07:17 PM
bollard n. a single iron or steel post or double vertical steel posts on a pier to which ships mooring lines are secured
I think no matter how you attach it it will sink your boat
I think you mean a bitt
Dave Finnegan
#11
Posted 04 July 2012 - 03:17 AM
http://www.duckworks...j/015/index.cfm
To look at the two, the engineering doesn't look the same. One simply bolts on to whatever is below (as do cleats). Those who describe the wooden versions that run through the deck to the keel make them sound like they have to be built strong enough to survive life threatening events on a daily basis.
Clearly the leverage that is exerted on the taller metal samson post is greater than that of a deck cleat, but how much more? Enough to matter?
#12
Posted 04 July 2012 - 05:46 AM
samson post n (2) In small boats and pleasure craft, a stout bitt near the bow for use with ground tackle
I never heard a bitt called a samson post, but I guess it can be under certain circumstances.
samson posts n (1) A short mast or spar that supports auxiliary cargo booms
This is the one I am familiar with.
Oh, and to give credit where due the above definitions are from:
The Facts on File Dictionary of Nautical Terms by
Thompson Lenfestey
I would not want one that is tall at all, especially if bolted on. I use a bronze one that is 6" and has a 4 bolt base that is almost that square on the foredeck of my Renegade. That puts the load about 3 " above the deck at most. I feel really secure about my boat at the mooring. I loop the eye splice of the pendant over the bitt then lash it down with a small line spliced to the pendant. This puts the load right at the deck with virtually no leverage. For a displacement hull boat I really like the bitt aka samson post. For a light weight boat like a CS I don't think it is necessary, a good cleat well secured either by through bolting or as Par describes is quite sufficient for towing, ground tackle or dock lines.
Dave Finnegan
#13
Posted 04 July 2012 - 08:55 AM
Wes Kisting
#14
Posted 05 July 2012 - 11:00 AM
i did ultimately decide that putting the clear before the mast didn't make any sense. Since the king plank extends beyond the forward bulkhead, i can through-bolt it there where it is in reach of the cockpit and send lines forward through chocks at the bow.
Joe
#15
Posted 05 July 2012 - 12:20 PM
But as for that cleat (be it mooring, deck, dock or boat), I'd suggest going one or two sizes up from what you might think. I think the cleat on my 17 foot sloop is around 6 inches and it could stand to be bigger, or else have two in tandem. Two lines for anything maxes it out.
#16
Posted 08 July 2012 - 11:54 AM
BRS 15 "Mysz"
#17
Posted 08 July 2012 - 08:45 PM
#18
Posted 11 September 2012 - 08:50 PM
#19
Posted 12 September 2012 - 04:10 AM
It's kind of like rigging a clothes line with the boat in the middle where one end is a block at shore; the other end is a block that is either an anchored block, a block attached to a mooring buoy (for more bottom clearance), or a block attached to another anchored boat.
See also an example at http://gisamateur.bl...?q=Anchor video
And the related thread: http://forum.woodenb...p-of-the-season
#20
Posted 12 September 2012 - 05:19 PM
