I am using much fancier wood this time and I really didn't like doing the heat gun thing on the last coaming, so I'm soaking the strips of wood and pre-bending them. I'll let them dry several days and try gluing them (think I well use epoxy this time). I've got to figure out something so I don't epoxy it to my table or pegs. Here are two strips bent around. I really find this much easier with the pegs. I used plenty of pegs so I can really clamp it up. We'll see how it all works out.
Making My Second Coaming
#1
Posted 12 May 2012 - 03:33 PM
1st build - Curlew
#2
Posted 12 May 2012 - 03:36 PM
Waxed paper.
Dave Finnegan
#3
Posted 13 May 2012 - 04:17 AM
#4
Posted 13 May 2012 - 07:01 AM
I cut the coaming strips to 3/32" thick, using the Ash, I had no problem bending and only had to use the heat gun on the small side of the radius about half of the time.
#5
Posted 13 May 2012 - 07:31 AM
1st build - Curlew
#6
Posted 13 May 2012 - 07:54 AM
Kudzu Craft SOF kayaks
www.kudzucraft.com
#7
Posted 13 May 2012 - 09:23 AM
#8
Posted 13 May 2012 - 10:23 AM
1st build - Curlew
#9
Posted 13 May 2012 - 01:47 PM
1st build - Curlew
#10
Posted 13 May 2012 - 03:39 PM
Dave Finnegan
#11
Posted 13 May 2012 - 05:08 PM
1st build - Curlew
#12
Posted 13 May 2012 - 05:18 PM
#13
Posted 13 May 2012 - 05:49 PM
Soaking the strips in water and clamping it up I noticed it remains wet where they overlap on the inside...and dry fast on the outside which causes the wood to cup.....a challenge to deal with that....
Yes I have noticed a little. I'm hoping that when I glue, if I put some sticks between the clamp and the coaming, with as many clamps as I'm using it will flatten them out. It's very little so far. I wish I had done it while I was pre-bending with them wet, but too late now. It's mostly where I use C-clamps because most the pressure end up in the center of the strip. I tried turning the c-clamps around for the bigger flat piece "c" was against the strip, but I didn't have enough room inside the coaming. except in a few places.
1st build - Curlew
#14
Posted 13 May 2012 - 06:21 PM
Thinks, I have some from Raka. Mine makes a white-ish paste. I also hafe some red-ish filler, may add some and see if I get some near my wood color. May turn out pink though.
The whitish will go virtually clear when it cures, I suggest you use the colloidal silica. The reddish filler is likely micro-ballons and is intended to thicken epoxy as a surface filler or filet material, not an adhesive. Each filler gives the epoxy different characteristics, they are not interchangeable for all applications
The soaking is why this happens. There is less cupping if any if you use very hot water and only dip the strips for a minute or so. I mark on the strip the section that will go around the tight curve at the forward end of the coaming and dip just that part into a wide baking pan of boiling water and immediately bend it around the form and clamp it. It also dries a lot faster if not saturated. Some people use a cloth wet with hot water and find this is sufficient.
Dave Finnegan
#15
Posted 13 May 2012 - 07:11 PM
Hey! here it is but more than $19.95
1st build - Curlew
#16
Posted 14 May 2012 - 04:27 AM
www.kudzucraft.com
#17
Posted 14 May 2012 - 07:20 AM
Phenolic hollow reddish brown spheres that make excellent light weight putties with superior feather edge sanding qualities. They sand easier, smoother and have better sag resistant properties than the white bubbles. Phenolic is the best quality filler for an easy sanding fairing putty.
Fumed silica known as Carbosil or aerosil is the most commonly used filler and makes a very smooth strong non sagging putty and is often added to other fillers to improve their properties. Fumed silica can be added to make a smoother paste.
This confirms that the fillers are what I thought they were and the equivalent to West System 407 micro-balloons and 406 colloidal silica
Dave Finnegan
#18
Posted 14 May 2012 - 08:03 AM
From what I have read heat, not moisture is what makes wood bend. If you soak it, you have to let it dry before you can glue it so I am a bit leery of soaking word.
You are correct, I would not recommend this procedure. I'm going to finish it up after it dries well and see how it looks. If it doesn't work out, then I get to build another. I do like the peg board though.
Raka website says the following:
So it's Fumed silica, okay, Phenolic no?
1st build - Curlew
#19
Posted 14 May 2012 - 01:04 PM
As a filler for adhesive that is correct. If you want to make a surface putty use the phenolic hollow spheres aka micro-balloons.
Dave Finnegan
#20
Posted 16 May 2012 - 08:40 AM
1st build - Curlew
