Spindrift Quarter Knees & Breast Hook
mjshp
Ditto John = hull squared & true, seams fitteted & tapes, gunwales on, then you can fit the quarter knees & breasthook. No "coaxing of the hhull itself, all fitting adjustments to be made on the quarter knee and breasthook parts.
Good job Hull looks sweet. I am eagerly awaiting your post on the trauma of sawing the hull apart. Yeah, standing over the beautiful work of boat art with a Japanese pull saw in hand going ohmigod, ohmigod, have to SAW my boat in half! :-)
Thanks for all the help, so to claify the next steps are:
  1. square the boat
  2. attach gunwales with epoxy, if so, is a temporary backing plate enough for the guwales to be scrwed into at the bow and stern?
  3. filet & tape inside seams
  4. attach beast hook and quarter knees
My confusion stems from GB's instrucions which say
  1. Wire boat
  2. Make and install breasthook, knees and gunwales
  3. filtet and tape inside seams
Thanks for the advice.
Michael
Dry fit the gunwales to each side first, starting at the bow and gradually working toward the stern. Use a screw to secure them at the bow, then clamps along each side, working from bow to stern, keeping the sides symetrical. Be gradual and gentle bending the gunwales. A screw isn't necessary at the stern if you're using enough clamps. Once you're satisfied everything is in the right place and the hull is fair, release the clamps on one side, from back to front. Apply your epoxy (thickened), re-install the bow screw and repeat the clamping process, bow to stern. Once you're satisfied its clamped back in the right spot, the sides are still symetrical, and you've cleaned up the epoxy that has squeezed out, you're ready for side 2. You can do it right away or whenever. Just don't release the dry clamps until you're ready to glue it in place.
Understand why you might have been confused. Your revised order of events is correct.
