Epoxy bushing for heavier uses.
#1
Posted 28 July 2011 - 05:31 PM
I've started on the Princess Sharpie 26 (Hull #3). Just the fiddly bits like the centerboard and rudder. The centerboard pivot calls for the ol' epoxy bushing trick, and I've already poured it. But now I'm thinking that I should have used something other than straight epoxy- maybe something thickened with silica or milled glass for strength. That centerboard is about 5 feet long and the tip's weighted with 35lbs of lead. Any advice if I should drill out the epoxy and add something thickened? Or is that over-engineering?
#2
Posted 28 July 2011 - 06:03 PM
Definitely drill it out.Hey guys,
Any of the recommended structural extenders will make the difference.
Fumed silica, milled fibers, Cabosil, even wood flour if nothing else.
#3
Posted 28 July 2011 - 06:46 PM
As Graham only speccs resin bush and has specced beefier pin and bushing diameter I suspect it is fine as is.
The lead is only to make the board negatively bouyant once immersed.
Bigger point is to have that board resting on a support on the trailer going down the road rather than being supported by blocks and rope.
Building Dreams, One Boat at a Time
www.Greatfallsboatworks.com
ABYC Certified Marine Electrician
#4
Posted 28 July 2011 - 08:46 PM
Plain epoxy with cabosil as a thickener (it is not a structural additive)has been used very well in loaded pivot points for years with no problem. Milled fibers would strengthen the bushing but might increase friction and wear on the pin. Fumed silica and cabosil are the same thing.
#5
Posted 31 July 2011 - 02:02 PM
A related question falls out of this: silica thickened epoxy certainly seems harder, but I've also found it very brittle. I'm guessing a bushing would rather be elastic than brittle...
#6
Posted 31 July 2011 - 02:26 PM
#7
Posted 31 July 2011 - 04:49 PM
Everytime I look to improve on his design I come away feeling his way is better.
If you have the epoxy bushing poured I would leave well enough alone rather than drilling it out and redoing it with a different mix.
Yep when board is down, it will be down in the water and the bouyancy of the board will offset much of the weight.
When board is retracted and on trailer I would want some sort of tray to rest board on under trailer so you don't have continual shock with every bump in the road on the block and tackle and uphaul line. So stress on the pivot pin will be moot at that point.
#8
Posted 01 August 2011 - 01:46 PM
Sometimes they are using unthickend epoxy sometimes high density filler. In one paragraph they seem to be using the filler only to make installation easier on non horizontal surfaces.
They are testing the fasteners to failure both and shear and tension.
I did not see any mention of other additives.
Probably more important than additives is that you get an accurate, well mixed batch of epoxy.
#9
Posted 02 August 2011 - 04:17 AM
Dave Finnegan
