ffice" />Andsome other items. (Outboard Motor parts came from a closed repair shop down inMass)
CurrentList as of 07/01/2012
QTY DESCRIPTION New/Used PriceEa. Extended Price
1 TeleflexSeaStar steering Hydraulic Helm Tel Part# HA5418. New $400 $40
3 WaterPump Impeller Teleflex 18-3056 Impeller - Dia. 3 1/2",Dpth. 1 1/4" -6 Fins - Neoprene
Honda # 06192-ZW1-00 Fits Honda 75HP and Mercs 4743026-2 and others. New $17 $51
4 Johnson/EvinrudeNew Stainless Steel Steering arms for outboards ( Will fit other brands) New $50 $200
1 Johnson/EvinrudeAlum Propeller, NEW, 14 X 19 #176215, 13 splines fits Johnson/Evenrude New $100
1 Johnson/EvinrudeTilt Pins retainer Bars for Johnson/Evinrudes ( Will fit other brands) New $20
2 Johnson/EvinrudeVRO hose & Pump & Sender New $100 $200
1 Johnson/EvinrudeTRIMTAB 327640 OMC New $20
1 Johnson/ EvinrudeVROKit Part # 438406 includes Pump #175161 New $250
3 Johnson/Evinrude #323664 Spline Gear New $99 $297
3 HelicalLower unit Gear sets 340490 New $199 $597
1 Johnson/EvinrudeNew Rectifier/Regulator Kit # 395391 New $150 $150
1 Johnson/EvinrudeIgnition Coil Kit # 583737 New $99 $99.00
2 Johnson/EvinrudeIgnition coils #582508-0560-0A New $25 $50.00
2 Johnson/EvinrudePOWER PACKS OMC CD4 584027 New $85 $170
1 Johnson/EvinrudeVoltage Regulator Kit # 173640 New $189 $189
2 Johnson/EvinrudeTimer Base Kit #583376 New $200 $200
1 Johnson/Evinrudewiring electrical harness for controls to engine with big red plugs New $80 $80
Johnson/EvinrudeWater Pump Impellers for 85-150 HP New $15 $15
Johnson/EvinrudeComplete Water Pump kit for ? HP #391391 New $50 $50
Johnson/EvinrudeCompleteWater Pump kit for 85-150 HP Part # New $50 $50
Johnson/EvinrudeEvinrude Johnson 3" Tach & System Check Gauge. New $150 $150
2 Johnson/EvinrudeTrim Indicator Gages New $50 $100
1 Johnson/Evinrudelower unit Gasket #286279-2 New $20 $20
1 Johnson/EvinrudeComplete Gasket set #139300 fit 85 to150 HP V4 motors New $50
2 Johnson/EvinrudeRubber Exhaust Gaskets fit 85 to 150 HP V4 motors New $10 $20
6 Johnson/EvinrudeGaskets # 317914 fit 85 to 150 HP V4motors New $6 $36
1 Johnson/EvinrudeGasket # 359-317955-1 New $8 $8
9 Johnson/EvinrudeGaskets # 194-321727-1 New $8 $72
1 Johnson/EvinrudeGasket # 436-323459-1 New $8 $8
5 Johnson/EvinrudeGasket # ???? New $6 $30
2 Johnson/Evinrude Helical Lower unit Gear sets # 340490 New $199 $398
4 Johnson/Evinrude90HP-150HP Rod Bearings set New $50 $200
10 BrandNew Valves for Inflateable Boats. New $25 $250
New
1 CMC.PT-130 Transom Clamp Motor Adapter (#13022) New $50
2 AquaPower Impeller JP 28948-001OMC #509182 Fits Jabsco Seawater Used $20 $40 3
Teleflex 18-3056 Impeller Dia. 3 1/2",Dpth. 11/4" 6 Fins NeopreFits Honda 75 to 150 and Mercs and others. New $17 $51
3 #323664Spline Gear New $99 $297
1 IgnitionCoil Kit # 583737 New $99
1 VoltageRegulator Kit # 173640 New $189
2 HelicalLower unit Gear sets 340490 New $199 $400
2 RubberExhaust Gaskets New $10 $20
1 Complete90 Hp Gasket set # 139300 New $50
1 Gaskets# 317914 New $6
2 usedOMC Stator #583669, #583672, New $50 $100
2 usedJOHNSON/ Evinrude Stator #583669, #583672, New $40 $80
1 Johnson/EvinrudeZinc TRIM TAB 327640 New $20
2 Johnson/EvinrudeNew $50 $100
2 Johnson/Evinrudefuel fitings New $8 $16
1 Johnson/Evinrudeset of new plastic engine throttle connector slides New $20
1 Johnson/EvinrudeVRO Oil Tank with hose & Pump & Sender New
$100
1 FuelFittings Set male & Female old style Merc New $15 $100
1 FuelFitting Honda New $10
Teleflexthrottle/shift CABLES OMC Johnson/Evinrude Just $1 per foot. New
2 TeleflexBlack 12ft t shift/throttle cable OMC New $15 $30
1 TeleflexBlack 15ft t shift/throttle cable OMC, Johnson/Evinrude New
$15
1 TeleflexBlack 23 ft shift/throttle cable MERC New $25
1 TeleflexBlack plastic steering wheel New $15
1 remotesteering Alum Bracket for the Merc/Force 9.9 or 15HP outboard motor. ( May fitother brands) New $40
2 BatteryRotary Switchs Used $25 $50
2 Johnson/Evinrudeelectric fuel chokes Used $25 $50
1 TimerBase Kit #583376 Used $100
1 Johnson/EvinrudeRectifier/Regulator # 395391 Used $85
1 RecoilStarter Assembly for Merc/Force 9.9 or 15HP outboard motor. Used $50
1 factoryservice manualfor Merc/Force 9.9 or 15HP outboard motor
Used $40
4 TiltPins retainer Bars for Johnson/Evinrudes Used $20 $80
2 StainlessSteel Steering arms for outboards Used $40 $80
2 StainlessSteel Steering Coupler brackets Used $40 $80
2 Johnson/EvinrudeIgnition coils #582508-0560-0A Used $99
1 Johnson/EvinrudeOMC Stator #583672 Used $75
1 Johnson/EvinrudeOMC Stator #583669, Used $75
4 Johnson/Evinrudeignition coils Used $10 $20
2 Johnson/EvinrudeFlywheel Used $100 $200
1 Johnson/EvinrudShift/Throttle control Housing Used $40
1 Johnson/EvinrudePlastic Fuel Tanks Used $20
3 Johnson/EvinrudeTRIM TAB (adjusts outboard torque) 327640 Used $20 $60
1 Johnson/Evinrude throttle/shift control Used $50 $50
1 Johnson/Evinrudethrottle/shift control, missing a few parts Used $25 $25
4 Johnson/EvinrudeBig heavy Alum wedge Motor Mounting Brackets to shim up outboard on transom Used $40 $120
1 Johnson/Evinrudecomplete wiring electrical harness with lots of electrical parts from Johnson90HP V 4 Used $100 $100
1 Johnson/Evinrudewiring electrical harness for controls to engine with big red plugs Used $50 $50
2 Johnson/EvinrudeTachometer Used $10 $20
1 LOWRANCEBlue water Pro Flasher/Paper chart recorder Fishfinder with transducer. Used $150
1 RAYNAV520 Loran with coupler Used $50 $50
1 Apelcohandheld GPS 15 with dashboard mountingbracket Used $100
1 RaytheonVHF/TV Anttena Dome Used $50
4 Factory& Aftermarket Marine Outboard Motor Repair Manuals Johnson, Mercury, Force,Subaru Used $10 $40
1 pairLarge indoor/Outdoor waterproof speakersused Used $40 $40
1 pairSmall indoor/Outdoor waterproof speakers used Used $40 $40
2 TwoPower tilt motors for older OMC I/O outdrive. Unknown condition need rebuild. Used $20 $40
1 Bronze11/2 Prop Nut Used $5
1 FuelHose with Fuel Fittings & Primer old style Merc Used $10 $10
1 FuelFittings Set male & Female old style Merc Used $10 $10
1 pairof Alum/Plastic oars for inflateable boat Used $20 $20
2 Childclass 3 life preservers Used $4 $8
2 ClassI Life Preservers Used $25 $50
1 30inch USCG Approved Orange life ring Used $45 $45
Capt@Wickedgoodoutdoors.com
