Maria CS20 104 Posted May 27, 2009 Report Share Posted May 27, 2009 Hey all, still working on the beast and enjoying it all. Question for all experts: How many coats of epoxy are recommended for the internals of the seat tanks and forward compartment? Currently have done two, three seems okay but 4 seems overkill. Thanks for the input Jim Quote Link to comment Share on other sites More sharing options...
PAR Posted May 27, 2009 Report Share Posted May 27, 2009 Three is my usual recommendation. If all the surfaces are equally glossy, then it's coated well enough. Quote Link to comment Share on other sites More sharing options...
John Burritt Posted May 27, 2009 Report Share Posted May 27, 2009 Three should be fine. Just double check the joints, seams, end-grains & edges to make sure they're well sealed and there's no place water can sneak in. The flat surfaces are the easy part. Quote Link to comment Share on other sites More sharing options...
Maria CS20 104 Posted May 28, 2009 Author Report Share Posted May 28, 2009 THanks fellows, I am redoing the forward mast step as my original does not fit at all and I KEPT FIGHTING IT stupid me. Easier to redo and it makes more sense for installation of the unit. Redoing the part that must be scored to the hull was easier than I thought it would be, first one was a mess. Used a flattened bunch of chicken wire to make a curved template on its edge. Smashed wire is about the width of a ruler wrapped in blue masking tape, on edge pretty ridged and easy to shape into the curvature of the hull. Sanded into final shape. Last unit I made I put the top triangle on and then spen forever trying to figure how on earth I was going to fillet it into place. This time I glued the stringers into place that give a larger surface to glue down top, setting up now. Once dry I plan to install the shaped piece so it is square up and down and centered n the hull. Next I think I will be gluing down the top piece and fileting and taping up. Fun stuff but time consuming, oh well, worth it as it comes together. Thanks Again Jim Quote Link to comment Share on other sites More sharing options...
