WI.northern exposure Posted March 26, 2017 Report Share Posted March 26, 2017 (edited) Hello All, I am new to this Forum. I have plans to build the "Stonefly" canoe. I have a general question about the placement of the 1/2 inch plywwood frames. So, if the plans say the placement is at 2' 0", does this mean that the center line of the frame is 2' 0" , or would this be the position of the brackets ? I have tried to find the answer to this in Jeff's plans and building manual. , as well as this forum, but have yet to have my question resolved. Thank you in advance for the answer. Edited March 26, 2017 by WI.northern exposure Quote Link to comment Share on other sites More sharing options...
benhardt57 Posted March 27, 2017 Report Share Posted March 27, 2017 I believe it doesn't matter as long as you are consistant. If you measure to the back face of your 2' frame, make sure you measure to the back face on all the other frames too. Quote Link to comment Share on other sites More sharing options...
Kudzu Posted March 27, 2017 Report Share Posted March 27, 2017 It is center to center but what bernhardt57 said is correct. Just be consistent and it results in the same location. Quote Link to comment Share on other sites More sharing options...
WI.northern exposure Posted March 28, 2017 Author Report Share Posted March 28, 2017 Thank you so much. That make perfect sense. I am getting so much information out of this forum. It is a really great resource. Quote Link to comment Share on other sites More sharing options...
bigtoepony Posted March 27, 2019 Report Share Posted March 27, 2019 That is interesting. My thought would be that they go on the down hill side of the line - so if the hull tapers to the left then put it on the left side of the mark. That way when you shape the frames stringer/gunwall cutout a bit so the stringer/gunwall sits nice against the frame the point where the frame is on the line has not been altered. Not much in it in the centre of the hull but a couple of mm in at at the end frames. What do you think? cheers Tony Quote Link to comment Share on other sites More sharing options...
