Search the Community
Showing results for tags 'core sound 17'.
More search options
  • Search By Tags
  • Search By Author
  • Boatbuilding
    • Main Forum
    • B & B Yachts Forum
    • Bluejacket Boats
    • Kudzu Craft Forum
    • Design Forum
  • Boating
    • Boating & Crusing Stories
    • Boat Maintenance
    • Classifieds
  • Woodworking
    • General Woodworking
    • Power and Hand Tools
    • Shop Built Tools and Jigs
  • HOSTkabob Support Forums
    • Web Hosting Q & A
    • Website Q & A
Calendars
  • Community Calendar
Found 2 results
  1. I really like the design of the Core Sound 17 and would like to see one in person. Are there any builders of Core Sound 17 in Minnesota or Wisconsin that want to show off their boat? I live in the Minneapolis / St Paul area and am willing to drive to see your boat. Steve
  2. Hi All, I've got a related thread going on my keel maintenance project (link below) but this is a little more specific. I've combed the forums some but haven't found what I'm looking for. Feel free to point me the right direction if you know of something. Anyway...the keel-replacement project is growing the more I look at the bottom and on one of the seams on my Core Sound 17, there is enough unevenness to want to fair it out. However, I've trying to avoid using fairing compound because I don't like the idea of sanding down to get to the epoxy because I've found that so far I end up hitting the weave of the fiberglass and I don't want to go all the way to wood, re-epoxy, reglass, and then prime/fair/etc. If there is an easy way to strip it (latex paint) without doing that, I'm all ears. In lieu of fairing compound, I've been thinking that I could scrub enough of the paint to get down to the primer only and then put high build primer on and go from there. I'm not looking for a perfect finish--or even close. I want to get this boat ready to get back on the water. But the seam is bad enough that I prefer to tackle this much while I have it flipped over. So specifically (though I am open to a whole different approach too)... 1) What high-build primer is good for this application? Looking for specific product recommendations. Only want to buy a quart. 2) Are there better ways to remove the paint without harming the weave? (I'd be ok with fairing compound if I could get a good starting point that the compound would stick too.) I will be repainting the whole bottom with the same paint I already have since it's (a) the same color and (b) the same as what was put on originally. All of course once I am done with fairing this bit out, attaching the keel+skeg and reinforcing the bow for abrasion with Xynole. Thanks in advance. -Bryan
